Windows 10 also makes handheld tune loaders play up, so I'd say Vag Com is not yet compatible, best ask Ross Tech.
Windows 10 sucks.
Hi Guys
I'm trying Vag Com for the first time since upgrading and it just stops working and windows doesn't seem to know why.
Any tips? Same old B5 Passat
Trev
Windows 10 sucks.
mine works in Windows 10. what you can try is reinstall the VCDS software
Tig 162 R-Line; Audi TT
Yes, try a re-install. It works on my laptop with 10.
hmm........ What version of VCDS cable do you have? Like Ops above, I've been using my HEX+CAN with previous version SW successfully on Window 10 for quite a while (64 Bit operating system).
I also recently upgraded to the latest version software (Beta 16.3.1.1) - re-flashed the firmware in the cable and not a problem using windows 10.
Have you pressed the "save" button after testing the USB port - after using the newly loaded software for the first-time?
It's most likely a Win 10 issue with your PC, release version & current beta certified & working correctly on Windows 10.
My16 Golf Alltrack, DAP
MY18 Golf Comfortline
