Results 1 to 7 of 7
Thread: VAG CAN PRO anyone got it?
    Apr 2009
    Northern Tasmania
    This seems a viable alternative to VCDS
    VAG CAN PROFESSIONAL 195 euros (A$240) delivered
    Site looks a bit bland, but it seems ok. Could someone with a VCDS have a look and see what they think?
    Mindarie, Perth (WA)
    love the way they spell LEGAL (*LEAGAL*)
    instantly smells of bull****
    Much safer option is getting the Ross-Tech model
    Dec 2009
    Kew, VIC
    Quote Originally Posted by wfdTamar View Post
    The hardware is very possibly the same as RossTech (they make no claims to any patent on that, so far as I know.)
    What you're paying for with them is mostly the software and the really excellent backup.
    The only advantage this cable has over the Ross Tech one is the ability to read and write to the flash memory in the ECU but this is virtually useless to anyone here unless they had a bluefin and wanted backups of their tuned ECUs data at different stages or something.
    You can do this with a different $60~$80 cable anyway.
    Vagcom able for me at that price for the reasons mentioned above
    Apr 2009
    Northern Tasmania
    I asked a UK distributor and this is what they sent. Can anyone see things there that the VCDS doesn't do?
    'Please take your time to look at the functions , you will see that this is far superior than Vag Com.
    You have many extra functions including the possibility to make software updates and also the possibility to read the ecu flash .
    As well as many other features like :
    The VAG CAN PRO System is systematically developed with One-Click-Functions added. The objective is to simplify and automate more complicated service operations. With just a few clicks, and without needing to search information from technical service documentation, users are able to conduct useful procedures easily and quickly.
    LIST OF PROCEDURES:
    Clearing inspection message
    Activation of cruise control
    Deactivating passenger airbag
    Opening,closing electric handbrake
    DPF emergency regeneration(1.4,1.9,2.0,2.5 TDI PD)
    DPF emergency regeneration (3.0 TDI)
    Throttle adaptation - Otto engines with Drive-By-Wire
    Injector coding 2.7/3.0 TDI Common Rail
    Change units in instrument cluster
    Change language in instrument cluster
    Bluetooth activation Audi Q7/A6 model 4F
    Basic setting of Xenon range controller
    Calibration of G85 sensor
    Erasing / programming remote controllers
    Enable / disable Nordic mode (Low beam as Daylight running lights)
    Test FireUp of Webasto (PQ35 - Caddy/Touran/Golf/Tiguan/Passat)
    FillingUp Brake system (MK60/70 - Golf V / Passat / Altea / Leon)
    Turning on Pre-Fuel pump (eg. for bleeding)
    Enable / diable automatic door-lock
    Xenon-lights coding (with and w/o shutter)
    Enable / disable seatbelts warning light
    Recalibrating T3 DPF - sensor
    Enable / Disable "SystemTest" for ABS/ESP
    Tires pressure sensors coding (Passat B6/ Passat CC/ Jetta)
    Battery coding for battery manager
    Key coding for IMMO IV (PQ35 / 46)
    Unlocking of blocked Webasto
    Disable APS-function of Front wisher
    Calibration of ESP acceleration sensor G200
    Calibration of ESP pressure sensor G201
    Change microphone gain in Nokia Handsfree set
    Calibration of ESP acceleration sensor G251
    Setting brake pad tickness - Audi A8
    Activating convenience automatic window opening
    Activating automatic side mirror flipping
    Activating Coming-Home / Leaving home functions
    DPF Adaptation after replacement 2.0/2.7/3.0 TDi / VW Crafter
    DPF Checking 2.0TDi / 2.7-3.0TDi
    Activating graphical Park assistant Audi A6/Q7
    LHD/RHD ESP Coding
    Injectors checking 3.0/2.7 TDI
    Unlocking Eject button in MMI DVD Drive
    Coding MMI Device List
    Activating/Deactivating tire pressure monitoring Audi A6 model 4F
    Pump-jet checking 1.9/2.0 TDI
    Recoding ABS/ESP variant (USA/EU)
    Adaptation new engine ECU for IMMO3 systems
    DPF Emergency regeneration VW Crafter, engines CExx, BJx
    ESP sensor calibration G200,G202,G251 in cars newer than 06.2007
    Adaptation of turbocharger in 2.7/3.0TDi engines
    Setting up service interval display
    Acceleration measuring
    Recoding of door electronics variant (LHD/RHD)
    Adaptation ESP ECU for DSG Gearbox in Audi A3 8P MJ2006
    Activation/deactivation MMI hidden service menu
    Adaptation of flap motors in 3.0/2.7 TDi engines
    Reading milleage from EDC15
    Testing Mass air flow meter G70 in TDI engines
    DPF emergency regeneration in BLE engines - Touareg 5.0 TDI
    Setting up PWM value for front LED daylight running lights - Audi A6 2009
    Setting up idle speed in Gasoline/TDI engines
    Unlocking TV function in MMI 2G/3G Systems
    Upload data from ZDC-Container
    Function check of EPB
    Activation of service menu in RNS510 Navigation system
    Activation of DRL using fog lights in BCM system
    Instruments recode for Audi A6/Q7 MY2009 from US-Units to EU-units
    Recode of TV -Tuner from US Specs to EU in Audi A8/A6/A4 8K
    Chiptuning test'
    vic
    "Thanks, but no thanks"
    edit: forgot this one here:
    I can see that is good value for some simple pre-loaded tasks but I'd like to know how it goes with things like logging and how many samples a second it can manage. There's not much info about it logging capability anywhere and this is what I use my cable for 95% of the time.
