Results 1 to 4 of 4
Thread: URGENT HELP - Buying Passat but has VCDS ERROR
    Mar 2011
    Lidcombe, NSW
    Hi Guys,
    Looking at locking in a deal real soon.
    Have had an inspection today and has the following error:
    Initial Scan showed the following FAULT
    15 | 37 - Navigation FAULT | 1
    5 | 09 - Cent. Elec FAULT |1
    9 | 17 - instruments FAULT | 1
    10 | 19 - CAN Gateway FAULT | 2
    Radio - Sporadic 004 - no signal/communication
    OI300 - Control module for navigation with cd-rom J401 - Sporadic 004 - no signal/communication
    That's all the information I have.
    In terms of what the car comes with...
    Options are:
    Dynaudio, GPS, Aftermarket bluetooth that pairs with RNS510, Sunroof
    Errors I currently know of is 1 blown parker light bulb
    Any help at all is appreciated!!!
    Thanks
    Roland
    The information you have posted doesn't give enough to go on.
    Your sporadic on signal could be someone disconnecting the radio with the ignition on.
    You should clear all codes and see what comes back and then post the full fault description that comes off VCDS.
    Quote Originally Posted by Rolls View Post
    Hi Guys,
    Options are:
    Thanks
    Roland
    Dec 2008
    Sydney/Canberra
    Nothing to be concerned about.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2012
    Sinagra, Western Australia
    Likely codes weren't cleared after someone was playing with the radio, as said nothing to overly be concerned about.
