Results 1 to 10 of 11
Thread: Updated Can Gateway from 1K0 907 530 F to 1K0 907 530 AD still draining battery!?
    Nov 2007
    NSW
    Hey all,
    I know this issue has been bashed to death on every forum in the world, but im wondering if anyone has had the same issue with thier Can Gateway upgrade.
    After installing an RCD 510 and upgrading the Gateway from 1k0 907 530 F to the 1K0 907 530 AD, im still getting the infamous battery drain.
    All coding was copied via VCDS on the installation list as well the long coding but no luck.
    I did somehow get it where the RCD510 unit displayed something about "battery drain", but I have not been able to replicate that again and now its back to its old problem.
    Do I just assume its a dud and go for the latest releaes 7N0 907 530 H gateway?
    Thanks in advance and please let me know if this has been covered already as i have searched high and low..
    Cheers.
    Adelaide hills, SA
    What software version is it? You should see the 4 digit number in the vcds, something like 0170.
    Nov 2007
    NSW
    Gateway: H16 0233 (as per VCDS)
    Adelaide hills, SA
    That should be compatible. Did you measure the battery drain? You could remove the fuse from the radio for a few days to make sure that it's the radio that cause the drain. How old is the battery? It could also be that your battery doesn't hold the charge.
    Nov 2007
    NSW
    I have actually had the battery replaced due to the constant drain and have been doing the fuse thing for months now.
    Takes a couple of days before it drains it totally.
    I only just had the micro can cable udgraded and delivered few days ago and installed the new gateway yesterday flat again this morning.
    It should shut down after 15min?
    Oct 2010
    Perth, WA
    Quote Originally Posted by mikk@ View Post
    Hey
    Did you solve this problem? I am having the same problem; however, after installing a 7N0 gateway... still getting battery drain over the course of 2 weeks.
    Mar 2013
    Mid North Coast
    Quote Originally Posted by remigi View Post
    Hey
    hey, i don't know if this will help but i have heard if you have a factory installed amplifier you don't need to update the canbus. It won't have a battery drain if you just plug the stereo in rather than updating the canbus. Obviously if you don't have a factory amp this doesn't apply.
    07 Jetta Tdi, DSG(tuned),Gtb1756vk turbo, 3inch dump, Malone tune, 4bar map, EGR+EGR Cooler delete, S3 Intercooler, Hard pipe kit, Gti rear sway bar, 18x8 Enkeii gtc01, nitto tyres, Rear Lip Spoiler, Votex Front Lip, Slotted and drilled rear Discs, Neuspeed springs, LED interior lights, Blackened window trims, Carbon covered pillars, Gti lower front Grill, canbus update, rcd510, tinted indicators, gti paddle shift wheel, soon to have Votex Side Skirts, Coilovers, Porsche Brakes,8mm wheel spacers, Alloy control arms, GTI front sway bar, S3 bushings....
    Adelaide hills, SA
    Quote Originally Posted by bgcarter1 View Post
    The safest way is to check if the diagnostic interface need a software update and get it updated or replaced.
    Jan 2015
    qld
    digging this up... has this been resolved??
    everywhere I have read bar 2 ppl say the 1K0 907 530 AD gateway works fine.
    I have a 10/2005 mk5 golf. just installed rcd510 and the above gateway however the headunit can be switched on at anytime. IE: seems like it has no switched power going to the head unit. <---- is this the batt drain issue
    the gateway was programmed with a snap on tool. is their further coding within the gateway module that I'm not seeing with a scan tool?
    Oct 2014
    Head unit power is always available - so you can then it on without ignition. That is normal. Drain happens because unit doesn't get correct shut down signal when ignition is off and stays in intermediate state.
    Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
    Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
