Results 1 to 6 of 6
Thread: Tiguan Indirect TPMS
    Aug 2011
    Melbourne, Victoria
    Question Tiguan Indirect TPMS
    G'day folks,
    Was wondering if anyone has cracked this? The module used in the Tiguan isn't the same as the Golf so it isn't straight forward seemingly to enable. The suggestion from Ross-tech's software is to change the coding on the ABS module +0002048, however, the resultant number is "out of range" for the module and results in a fail.
    Trying to enable it on a MY 12 Tiguan Manual (poverty pack)
    Any assistance most appreciated.
    Mackay QLD
    i have done extensive research on this and can confirm the coding for activating this function is by adding 4096 to your existing coding. Dana from Ross Tech removed this value from the ABS module code value in her own personal car and the function dissappeared from the MFD. VW have been smart about it and it appears you need to recode or reflash the ABS module using the SVM method much like what you would do to upgrade the BIOS on your computer to add this function to your Tig. To my knowledge the only software that does it is VW's own VAS system but happy to be prooved wrong.
    BTW +2048 indicates the vehicle is a RHD model.
    MY 21 T Cross 85TSI Life| Makena Turquoise | Driver Assist Package |
    Mods: VCDS tweaks |
    Apr 2008
    Have you installed the TPMS switch into the ABS loom Mythik?
    Mackay QLD
    Quote Originally Posted by benough View Post
    No physical switch anymore with the face lifted Tiguans. New ABS module TPMS reset now done via the MFD and is documented in the owner's manual
    Mods: VCDS tweaks |
    Erskineville, NSW
    When you go into the ABS controller module with VCDS does a pale yellow box pop-up with various vehicle specs on the right & numbers down the LHS?
    If you could post a screen shot of that?
    Apr 2008
    Quote Originally Posted by Bambazonke View Post
    Nice.
    Well I'm out of my depth now then
