Will do it tonight after work / tomorrow morning for you.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
Just ran it again twice "back-to-back" as requested - the pump and clutch etc DIDN'T activate (not audiably anyway) on the 2nd test, but they did in the first.
1st test:
2nd test: (note current is zero because pump didnt activate in the 2nd test)
Thanks, My haldex is acting same. Did complete test on pump part by part, it work perfectly. Haldex oil service is done. Solenoid is also working. So it is either controller or complete haldex diff. Getting HPA performance haldex controller next week.
If it solves my problem all good. Otherwise long time frontwheel drive.
Finally haldex module showed an error code which is
Address 22: AWD Labels: None
Control Module Part Number: 0AY 907 554 E HW: 0AY 907 554 E
Component and/or Version: Haldex 4Motion 0043
Software Coding: 0000005
Work Shop Code: WSC 00000 000 00000
VCID: 4D91B420D45102762F5-8018
1 Fault Found:
02248 - Valve for Controlling Clutch Operating Angle (N373)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 12611 km
Time Indication: 0
Any one has some idea what could this be?
Why don't you get VW dealer to diagnose it?
You must have the new car warranty, it's 2013 model. Even, if they wouldn't honour your warranty because of the mods, at least you would get "an another opinion".
Have a look on Ross-tech as they have explanations for a lot of the faults there.
So after reading this, I may have a similar problem. It never occured to me as the car only has 30k on it but when the front wheels start slipping there is no power transfer to the rear wheels and the its stuck spinning just the one front wheel. Although this has only happened twice, once on snow, once on a slightly muddy surface, it does however screech wheels on hard take offs. Is this normal behavior or a likely fault?
thanks in advance
