Results 31 to 40 of 40
Thread: Tiguan Haldex Malfunction .. VCDS test help !
  1. #31
    Will do it tonight after work / tomorrow morning for you.
  2. #32
    Jun 2013
    Thanks Bud..
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
  3. #33
    Just ran it again twice "back-to-back" as requested - the pump and clutch etc DIDN'T activate (not audiably anyway) on the 2nd test, but they did in the first.
    1st test:
    2nd test: (note current is zero because pump didnt activate in the 2nd test)
  4. #34
    Jun 2013
    1st test:
    Thanks, My haldex is acting same. Did complete test on pump part by part, it work perfectly. Haldex oil service is done. Solenoid is also working. So it is either controller or complete haldex diff. Getting HPA performance haldex controller next week.
    If it solves my problem all good. Otherwise long time frontwheel drive.
  5. #35
    Jun 2013
    Finally haldex module showed an error code which is
    Address 22: AWD Labels: None
    Control Module Part Number: 0AY 907 554 E HW: 0AY 907 554 E
    Component and/or Version: Haldex 4Motion 0043
    Software Coding: 0000005
    Work Shop Code: WSC 00000 000 00000
    VCID: 4D91B420D45102762F5-8018
    1 Fault Found:
    02248 - Valve for Controlling Clutch Operating Angle (N373)
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 38
    Mileage: 12611 km
    Time Indication: 0
    Any one has some idea what could this be?
  6. #36
    Adelaide hills, SA
    Why don't you get VW dealer to diagnose it?
    You must have the new car warranty, it's 2013 model. Even, if they wouldn't honour your warranty because of the mods, at least you would get "an another opinion".
  7. #37
    Have a look on Ross-tech as they have explanations for a lot of the faults there.
    Jun 2013
    It would be my last option. Removing all mods and flashing back to original going to be costly and risky. That's why I need to diagnose before and if it is complete haldex failure all back to stock and go to the dealer. It is all about cost benefit analysis.
  9. #39
    Adelaide hills, SA
    Quote Originally Posted by Ramee View Post
    Either the way you taking a risk that they will find out that the car had increased performance. So, if it was me, I would play fair and took my chances and drive to the dealer with the car as is.
  10. #40
    Aug 2016
    Woonona
    So after reading this, I may have a similar problem. It never occured to me as the car only has 30k on it but when the front wheels start slipping there is no power transfer to the rear wheels and the its stuck spinning just the one front wheel. Although this has only happened twice, once on snow, once on a slightly muddy surface, it does however screech wheels on hard take offs. Is this normal behavior or a likely fault?
    thanks in advance
