No Problem - it's not just the processor that's different, different solenoids as well!
Okay...Thanks for great explanation. Anyway I am not trying to design a haldex. Just to find a root cause of the problem. There are three things can fail. Precharge pump, controller it self with the solonoid, or the whole hydraulic clutch system. If it is pump or controller I can fix myself only need to narrow down which part exactly. Already checked the pump it is working. If it is hydraulic clutch then need complete rear end. My hope it could be the controller.
That is why I asked someone here to run VCDS AWD output test twice back to back on their car and post the outcome. It only take 2 mins but still nothing. Thanks guys.
2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
I can run a scan on my Golf R this afternoon with VCDS if you tell me the steps to do it. Not sure if a Golf R scan will tell you the correct info though if they use different Haldex systems?
Edit: Just saw the VCDS info on your 1st post.
Ramee, from my experience with VCDS & Output tests, is you won't meet the conditional requirements when the car is in the air to run any tests.-
If you can find a patch of gravel somewhere out of harms way, launch the car & have an observer see what the rear wheels do (video it). That will show you very quickly if its functioning or not as the front will break traction immediately & the rears should kick in quickly.
The Factory Volkswagen tool runs a completely different test schedule to what is available in VCDS:
– Connect vehicle diagnosis and service information system -VAS 5052-.
– In the display, select “Running gear (repair group 01; 40 ... 49)”.
– Select “Four-wheel drive with Haldex coupling (4th generation)” on display.
– Select “01 - Self-diagnosis-capable system” on display.
– Select “Functions” on display.
– Select “final control diagnosis” on display.
– Follow directions on tester.
It would be a great help. Please keep the ignition on without starting the car. So you can clearly hear pump working. Go to AWD module in VCDS and run sequential test procedure.
It will go step by step with your command (mouse click) and start with pump off, then pump on and so on. During these steps it will show oil temp, pump current and , controller current usage. Please note down these values at different stages.
When test ends, go back to AWD module again and run same test again and note down these values again ( specially pump on and off stages).
please do not recycle power during two tests.
In my case second test run do not start pump again. I want to know this is normal or not. Also like to know current consumption in these stages.
Ok all done - ignition on only (engine off). Pretty sure i photographed every step. Could hear the pump and other bits and bobs working.
Note that the current was fluctuating a bit on some of the steps.
[QUOTE=Lucas_R;1004827]Ok all done - ignition on only (engine off). Pretty sure i photographed every step. Could hear the pump and other bits and bobs working.
][/QUOT
Thanks Buddy. I think you ran test twice and these pump on stage currants are from these two separate occasions. Is UT
Ive never been into the AWD section of VCDS before, so its all new to me in there. I just kept pressing the "Next" and "Activate" buttons, allowing 5 seconds or so at each step, until it said test finished.
Do you need me to do it again? Or do something else?
You did it good. Can you do what you did again until the end window shows up. And press " Done go back" button. Then go to AWD module again and run the test for the second time. Could you please do this back to back. Please post a pump on and off stage values in both first and second passes.
