Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: Tiguan Haldex Malfunction .. VCDS test help !
    Jun 2013
    Today morning while I was driving to work I felt my steering wheel is light and have fair amount of torque steer. Also from the take off s car front wheels started to spin throwing traction control indicator on the dash.
    So afternoon I put the car on jack stands, unfortunately no rear wheel spin in first gear. So haldex is not working properly.
    VCDS scan shows no error codes related to the Haldex yet.
    Then I ran VCDS haldex (22 AWD Module ) output sequential test and Pre charge pump worked loudly at the pump on stage. Strange thing is if I ran this test back to back twice pre charge pump will not work in the second time. It only works if I recycle the power ( recycle the ignition) and rerun the test procedure through VCDS.
    So I suspect problem could be the haldex controller instead of pump. I am asking if anyone has a VCDS could test this back to back twice on their car ( with out recycling the car power) and post the result It could be great help for me to decide which part is the culprit.
    Also this test shows the current use by the pump and controller. First current reading seams to be related to the pump. If reading is zero pump is not working.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    I have to admit I know nothing about this, however my only suggestion is that the pressure in the lines may not have changed between tests and therefore the pump would not need to have activated in the second test (line was already at max pressure).
    Similar to when you pump the brake pedal. Second time it's rock hard.
    So I'd suggest finding a way to release the pressure in your lines between tests. Not sure how to do this - maybe drive forward and reverse a bit???
    As I said I'm no expert but it sounds like there's no need for the pump to activate a second time.
    A guy with a Golf R had a very similar/same thing happen to his car a few months ago. Basically the Haldex pump shat itself making the car front wheel drive.
    A new Haldex unit was required. Here's the thread: http://www.vwgolf.net.au/showthread....c-Pump-Failure
    Adelaide hills, SA
    Are you sure that you have the test procedure and conditions right?
    ..., make sure that if you've made any changes as I can see you could've tried something as per your other thread here Tiguan stability control defeat. , that they don't cause your fault.
    Dec 2008
    Sydney/Canberra
    What condition are your tyres in?
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jun 2013
    Quote Originally Posted by Umai Naa!! View Post
    Tyres are in good condition. Only 12k on them with good amount of thread on all of them.
    Jun 2013
    This vcds test run in steps where you can switch on and off pump in different stages of test and can keep the pump running for long time. So it should be able to run the pump again in a next test cycle. I hope someone can test this twice and post the results. I am thinking pump drive circuit in haldex controller gone bad and need to.power cycle to get it working again.
    Dec 2008
    Sydney/Canberra
    Quote Originally Posted by Ramee View Post
    Cool, that's one of the fundamentals covered. Carry on.
    '01 Beetle 2.0
    Jun 2013
    Is their any special precautions I have to follow doing this test?
    Oh I haven't done any vcds craziness to disable stability control
    Jun 2013
    A new Haldex unit was required. Here's the thread: Haldex Hydraulic Pump Failure
    Yep. Same story... Now I hate front wheel drive Tigs. with 270 hp..
