Results 11 to 20 of 40
Thread: Tiguan Haldex Malfunction .. VCDS test help !
    Quote Originally Posted by Ramee View Post
    Yep. Same story... Now I hate front wheel drive Tigs. with 270 hp..
    Well IF your Haldex is infact dead.......you have 2 options (providing your warranty is bust due to mods).
    - Buy the HPA Haldex competition controller from HPA in Canada (about $1000). This allows you to adjust the front/rear bias. HPA Motorsports, Inc. - Haldex
    - Buy a 2nd hand Haldex from someone with a Golf R who has upgraded to the HPA controller. These go pretty cheap (circa $200). Here's a really cheap one off a low km Golf R: Golf R odds and ends extravaganza - come one, come all!
    Jun 2013
    Thanks a lot. I send him a msg. But not sure it will fit a Tig.
    I will give it a try.
    2013 Tiguan 155kW DSG | Leather | Bi Xenon's | Park Assist 2.0 | Panoramic Sunroof | RCD 510 | RVC | MDI
    Mods: APR K04 v3.1 | HPA Haldex | S3 Intercooler | Custom 3" Quad Tip Exhaust | Carbonio Intake | WL HD RSB | GFB DV+ | Koni Yellow Sport Struts & Eibach Springs | HP LCAs | Custom Audio ( Alpine MRX V70 , Audison Bit Ten , Dynamat , Stealth Sub ) | Car Tablet | CB Radio | Sports Pedals | RLine Door Sills | Wheel Arch Extensions | 3 Bar MAP & BKR8EIX | RT VCDS .... Performance: 0 - 100 km/h, 5.0 seconds ( Racelogic PBox tested ) Tiguan Build Thread
    Should be the same i believe. Worth a try for a measly $50. Cant imagine how much VW would charge for one.
    Jun 2013
    You don't want to know !! 2500AUD including gst for part alone & 3 weeks from
    Germany. What a joke..
    I heard what they recommend is to change whole rear end.
    Arrawarra
    Now, you've probably already gathered I'm no fan of launching our cars... Just out of interest, is this something that could be bought on by the stresses of launching?
    Quote Originally Posted by MGV View Post
    Possibly - although plenty of guys regularly drag race and circuit race their Golf R's etc and haven't reported any issues. The thread i posted earlier with the Golf R failure, that car has never been dragged.
    You need to diagnose it correctly firstly (in this case VW may need to do it).
    Secondly a Golf R runs a totally different Haldex controller to a Tiguan. If you buy a Golf R one, you will just blow more money for no reason.
    The "controller" cant be broken by launching as it only "controls". Your differential & the clutch plates are what has to take up shock loading in the rear differential. A failure to these components is extremely rare. We have run well over 600hp through these rear diffs, with repeated launching & never had an issue.
    The failures I have seen (hardware as above) are generally from a pump circuit fault not being picked up for some reason, & the car driven a lot of miles with the lamars fully engaged. The system is not designed for that.
    The other breakages we have seen is for some modified aftermarket Haldex controllers that do not free spin under braking - this shock loads the differential in a way it was never designed to have a force transmitted (basically backwards through the gears) - so avoid those controllers like the plague!
    Jun 2013
    Can you please explain the pump circuit failure thing bit more. If this happens what need to be replace ( I think this circuit is in the haldex controller it self.
    Ramee, the whole thing is hydraulic, controlled by electronics - this is why you need proper diagnosis. You can spend a week in Haldex school - but you have to go to Sweden for that.
