Bill: many thanks for the kind words - notwithstanding the quid-pro-quo kicker!!![Roll Eyes (Sarcastic)](https://www.vwwatercooled.com.au/forums/images/smilies/rolleyes.png)
Regardless of whether you have halogen, or HID headlights and irrespective of whether you are driving a NAR, or RoW model mk7, the low-beam lamps will be controlled by the "Leuchte-sets" Leuchte6ABL LC5 (left-side) and Leuchte7ABL RB1 (right-side). On HIDs, these Leuchte-sets also control high-beam (because the fittings are Bi-Xenon), but on incandescent assemblies, the Leucthe-set normally only contains the one leuchte-command: Abblendlicht links (left-side), or Abblendlicht rechts (right-side). The illumination level for the Halogen low-beam lamps is ALWAYS factory set by Dimmwert AB channel in these 2 x Leuchte-sets to 100 - so maximum value!
So this is a long way of saying - you can dim these lamps, but you can't increase the illumination level of the low-beams - alas!
To turn-on the front fogs when the rotary light switch is in the Parking Light position (as well as when the center detente is pulled-out) try this:
You haven't said, but I'm assuming that you are using OBD11
Go to the Central electrics module, then to adaptation, then:
Leuchte12NL LB45-Lichtfunktion C 12 (left-side) and Leuchte13NL RB5-Lichtfunktion C 13 (right-side) > only if the current setting is not active, change to Standlicht vorn (Positionslicht; Begrenzungslicht)
Leuchte12NL LB45-Dimmwert CD 12 (left-side) and Leuchte13NL RB5-Dimmwert CD 13 (right-side) > only if the current setting is 0, change to100
At some stage after you press the GO button (the green circle with tick), OBD11 will ask you for the magic number 31347.
