Results 1 to 5 of 5
Thread: Sydney Coding
    Jul 2012
    Sydney Coding
    Anyone in Sydney that can code the bulb failure warning to be turned off permanently, cruise control speed set display and rear window all the way down on my12 polo gti. Located Bankstown / Hurstville area. Will travel.
    PM your info and price
    Jul 2012
    Anyone?
    Im in Newcastle so no use to you unfortunately. If you struggle to find someone in Sydney then get in touch with this place: VCDS Coding and Diagnostics Sydney - Home | Facebook
    Apr 2008
    I've not seen anyone be able to turn off the bulb checking. It's usually because they are using LED globes without a resistor. Your rear window won't go any lower due to the amout of space in the door frame. What is CC speed set display?
    Quote Originally Posted by benough View Post
    Good points. If you buy good quality Canbus LED's then you wont have a bulb ckeck error. Places like iilumo or Supernova sell these. And yes the rear window in most cars will only go down so far due to the wheel arch shape in the rear door not allowing the window to go the whole way inside the door.
