RNS-510 help
Hey guys,
Purchased a second R36 Passat with what I believe a factory RNS510 with satnav. Original problem I had was that the fader control did not appear. This did appear once I coded it correctly. Now I get the below fault codes. Tried changing active speaker settings with no luck, even tried Dynaudio setting with no change. Brings me to my next question, how can you tell whether car has the dynaudio system? Please see scan results below.
cheers,
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 A HW: 1T0 035 680 A
Component: RNS-MID H05 1020
Revision: AB001001 Serial number: VWZ6Z7H7288092
Coding: 000100000100000000
Shop #: WSC 00000 000 00000
ASAM Dataset: ------------------------- ------
VCID: 2C5D1F81F69B
1 Fault Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 39584 km
Time Indication: 0
Date: 2011.09.09
Time: 20:20:55
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No SW: 3C0 035 456 K HW: 3C0 035 456 K
Component: 08K Audioverst. 0001
Revision: 00001000 Serial number: 00000000180207
VCID: 2855E391E263
No fault code found.
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2C5D1F81F69B
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 39584 km
Time Indication: 0
Date: 2011.09.09
Time: 20:20:55
Those errors indicate that the Unit has not been coded, most likely you have not entered a workshop code when coding, causing your coding to be ignored. When it asks for the codes, 3 separate numbers, each 3-5 digits long (I think), just enter any random numbers and you should be right. Wish I had a screen shot, but having a bit of trouble on my phone, anybody else care to help with that one?
EDIT:
Found a screen shot, look at the third coding screen... http://forums.tdiclub.com/showthread.php?t=258543
The three boxes, Workshop Code, Importer and Equipment should be replaced with numbers of your choice. Also cars with Dynaydio have an amplifier under one of the front seats I believe.
I definately haven't changed any workshop,importer or equipment codes, so think that may be my problem. Just need to work out if I have Dynaudio installed.
Also what is the difference between selecting "01 Volkswagen Sound System" and "06 Volkswagen Sound System (BAP DSP)"
Thanks heaps for your help.
- You may not post replies
- You may not edit your posts
Forum Rules
