^^^^ pascat: I don't know what type of car you have, but my understanding is that if the CAN gateway can measure it, it will be available for monitoring/recording through the VCDS cable. I assume that you have a genuine Ross Tech cable, or a VCP cable (don't get a clone, they are complete rubbish and they thieve legitimate IP).
Have you tried looking at the extensive list in Advanced Measuring Values for the control module of interest?
Can you command the car to do stuff via VCDS? If the module will allow you to change a parameter, then it's generally possible to make the change with a VCDS cable. The change can be either a coding string modification, or a change to an adaptation channel. Some control modules need a security code before changes can be made.
Can I set the cruise control speed, roll windows up and down, etc? Not sure about the cruise control speed (if you have the physical equipment installed, wouldn't you set this via the button on the steering wheel?), but depending on the car (and the control module) its generally possible to turn-on/off comfort eindoe opening/closing
