Page 5 of 6 FirstFirst ... 3456 LastLast
Results 41 to 50 of 56
Thread: Passat Coding changes
  1. #41
    Sep 2008
    Quote Originally Posted by Pana View Post
    is that after the thunderdome coz I was there a couple of weeks ago and didnt see one on the way....
    It's southbound, at the Bulla-Diggers Rest Road bridge.. was taped up and not in use last time I saw, but as I said, I very rarely use that section of the road.
    MY08 Passat 2.0 TDI Wagon
    Trialling golf ball aerodynamics theory - random pattern, administered about 1550 on Christmas Day, 2011.
  2. #42
    Oct 2009
    United Kingdom (UK!)
    ooh - nice info here.
    I have an older copy of VagCom I have always used for my Passat W8, but it doesn't "speak" to the R36. I'm angling for a new CAN capable copy of VCDS from my other half for Christmas!!
    Robert Bentley
    Passat R36 Saloon
  3. #43
    Aug 2009
    Melbourne, Vic
    Quote Originally Posted by Swallowtail View Post
    I've made a few coding changes using VCDS to my R36:
    4. Made the speedo more accurate - now reads 105 at 100kmh instead of 108...
    Just keep in mind that changing the impulse number to adjust the speedo also effects the Odometer but I suppose that is not big deal for most of us.
  4. #44
    Feb 2009
    Quote Originally Posted by logger View Post
    Mav's site indicates otherwise, and I have read some people saying it does and some saying it doesn't.
    Changing the impulse number doesn't change the CAN BUS speed, only the indicated speed. Why would they use a known (and deliberately set) wrong speed for the odometer? From me reading, the odometer is driven by the CAN BUS speed, so should not be affected by changing the impulse number...
    Just my 2c, and I could obviously be entirely wrong, but it seems logical to me.
  5. #45
    Aug 2009
    Melbourne, Vic
    If his site does say that then I believe it is probably incorrect. There is some other stuff there about the MFD speed warning indicating CAN bus speed which is demonstrably not the case with my car. I think the developers of VCDS Vag-Com, Ross Tech, can generally be relied upon to know how these things work, and I quote...
    "There is no known way to change the relationship between the speedo and the MFI and odometer via diagnostics. Changes to the Distance Impulse Number should affect all of these equally." Uwe Ross Oct 2009.
    I have no idea and it does not make a lot of sense but I would not discount what the Ross Tech fellas have to say.
    But having said this, the change to your ODO will probably only be small and easy enough to live with. For time being I have chosen to leave that setting alone in my car.
  6. #46
    Oct 2009
    Today i picked up my car from the service department at the dealer and when i turned off my car, i had the two back doors open and the next thing i know all 4 of the windows go down automatically in sync.. this seemed a little strange to me.. its never happened before.. anyone had this happen?
    2007 Golf GTI
    .. (Arsenal) ..
  7. #47
    Apr 2009
    Melbourne, VIC
    Were you holding the unlock button? Or was your pocket holding it?
  8. #48
    Apr 2008
    Quote Originally Posted by SaBiH View Post
    time to call GHOSTBUSTERS!!!
    how else did the 2 doors open?
    The Fräulein: Black .:R36 Wagon...all boxes ticked!!
    The German Mistress: 2001 Black B5 A4 1.8T
  9. #49
    May 2007
    No sure if this site has been mentioned yet...
    http://translate.google.com/translat...history_state0
    I got it from here...
    http://forums.vwvortex.com/zerothread?id=4643253
  10. #50
    Oct 2009
    Well I made the 'windows-up' on rain changes and the knock on effect is my rain sensor seems a whole load less sensitive under normal driving.
    Anybody else experienced this?
    Robert Bentley
    Passat R36 Saloon
