Page 6 of 6 FirstFirst ... 456
Results 51 to 56 of 56
Thread: Passat Coding changes
  1. #51
    Feb 2009
    Not that I'd noticed rob, but then we live in Australia LOL.
  2. #52
    Feb 2008
    Sydney, Australia
    Quote Originally Posted by Swallowtail View Post
    Cost me about $400 I think from memory. I think it's worth it - I've done the above, cleared error codes from the after market stereo install (they removed the VW amp, but the car was still looking for it) and have coded my Bluetooth install with it.
    And a couple of other people have borrowed it and used it to. One of them was to see what error codes were on a 2nd hand Passat they were buying.
    As a matter of interest, is there an issue with the car looking for the original amp if it has been removed? I also removed the original amp and fitted the ArcAudio ks125.4 amp like you did, but kept the factory speakers, which are really very good. I also added Dynamat and an Audison Bit One processor to iron out any anomolies.
  3. #53
    Feb 2008
    Sydney, Australia
    Mav's site indicates otherwise, and I have read some people saying it does and some saying it doesn't.
    Changing the impulse number doesn't change the CAN BUS speed, only the indicated speed. Why would they use a known (and deliberately set) wrong speed for the odometer? From me reading, the odometer is driven by the CAN BUS speed, so should not be affected by changing the impulse number...
    Just my 2c, and I could obviously be entirely wrong, but it seems logical to me.
    If the indicated speed on the speedo is higher than your actual speed, it may be for safety reasons so as you do not go over the speed limit?
  4. #54
    Oct 2009
    United Kingdom (UK!)
    Sorry - yes, I forgot to explain. Rain is when water falls from the Sky. Not sure you've ever seen it over there?
    Robert Bentley
    Passat R36 Saloon
  5. #55
    Feb 2009
    Quote Originally Posted by Lance B View Post
    I'm sure it is, but I don't need to be told I'm going 10kmh faster than I actually am.
    Nice amp hey? The factory speakers are average - you will notice a huge improvment if you replace particularly the front pair with some high quality splits. The car does look for the amp, and does create errors in the electronics if the amp is removed, not the end of the world though. A quick look in with VAGCOM to the car's config and tell it the amp isn't there any more fixes those errors.
    Quote Originally Posted by RobBentley View Post
    All too rarely these days unfortunately...
  6. #56
    Feb 2008
    Sydney, Australia
    Nice amp hey?
    It's an excellent amp for sure. I first had it bridged and only running the fronts with the standard amp running the rears. When it was bridged it gave out 250watts rms per channel (from memory) and so had some serious control over the speakers. Now I am running it on all four speakers and it is back to the "lowly" 75watts rms.
    The guys who installed all my equipment thought that they sounded great for a factory set up. They used a microphone and fed it through the set up of the Audison Bit One to get the levels right and the installer said that they are very well extended and quite punchy for bass and the top end is quite good. It is amazing what a system processor can do to make it sound excellent.
    I am just wondering what sort of electronic errors there could be. Do you know what they are?
