Page 11 of 16 FirstFirst ... 910111213 ... LastLast
Results 101 to 110 of 152
Thread: OBDEleven - The new kid on the block!
  1. #101
    Mar 2017
    Tasmania
    Obdeleven is a play on the visual representation of ‘OBDII’ - it looks like an ‘eleven’ (11). It’s just clever marketing. The Obdeleven dongle uses the obd2 port, as do a myriad of other obd2 compliant devices.
    what makes obdeleven unique is its coding abilities through the smarts of the app (and presumably some unique hardware in the dongle)
    I’m 110% happy with the obdeleven kit that I got through AutoInstruct.
    Oct 2015
    Thanks doc
    I used my generic wifi dongle and Carista (iOS) and managed to see some faults(surprised) and modify a few parameters, but none that I really wanted(traffic mainly)
  3. #103
    Mar 2017
    Tasmania
    I was happy to spend the money just to be able to get rid of the nag screen on the nag
    All the other changes i’ve made are just a bonus.
    Best change for me - setting the 4 motion system to “increased traction” on my Alltrack.
    Sydney Northern Beaches
    Quote Originally Posted by P_132TSI_Rline View Post
    Hi guys. New to all this stuf.
    Does anyone know how get this two things on with OBDELEVEN
    To get speed limit sign showing in dashboard?
    How to get iner headlights to be on with DRL lights?
    Much appreciate any help!
    I think this is how you display the speed limit using OBdeleven
    Traffic Sign Assist Activation (Car must be fitted with Camera)
    Vehicle camera will read traffic signs and display the posted speed in the cluster.
    Select Control unit 5F (Information Electrical)
    Adaptation
    Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21
    Değer=Active
    Select channel (151) vehicle menu operation-menu_display_road_sign_identification
    Değer=Active
    Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_thresho ld_high
    Değer=Active
    Control unit A5 (front / advance camera)
    Security access
    Access Code 20103
    Control unit Long Coding
    Byte 1
    Bit 0 Activate – “01 Traffic Sign Recognition (FTE) active”
    Select Control unit 17 (Dashboard)
    Byte 5
    Bit 2 Aktivate
    Adaptation
    Select : channel numbers indicate end of speed limit
    Importance to actively invest Show Valid suffix
    View Channel Valid suffix
    Corresponding value adjust default: 00100111
    This site also has a comprehensive list
    Volkswagen MK7 Golf OBDeleven / VCDS Tweaks List – AutoInstruct
    The Car: MY20 Black Golf R Final Edition, 5 Door, Driver assistance package, Sun Roof.
  5. #105
    Jan 2019
    Melbourne, Victoria
    Just ordered my OBDeleven from AutoInstruct. Excited to receive it and start poking around. Got a plan for what I'm going to do first. Thanks to all the people and forums that helped me identify what I wanted to do.
    1. Improve Turbo Lag
    • Module: 44 - Steering Assist
    • Security code 19249 Adaptations: Driving profile switchover
    • Switch ‘Incremental, controlled over time’ to 'Direct; controlled over threshold value'
    2. Improve Traction
    • Control Unit: 22 All Wheel Control
    • Acoustic Measure, Wiring Logic
    • Change from Standard to Increased Traction
    3. Set XDS to Weak
    • STG 03 (ABS)
    • STG Adjustment -> Function 10
    • Select: Expanded Electronic Differential Lock
    • Options: Weak, Normal, Hard -> Set to Weak
  6. #106
    Sep 2016
    I'm curious on the settings you're wanting to change
    Quote Originally Posted by GolfRSpecialEdition View Post
    How does something in steering-assistance module, affect turbo lag?
    What does this setting do exactly?
    3. Set XDS to Weak
    • STG 03 (ABS)
    Why do you want it weaker than the standard setting?
    2016 Skoda Octavia 162TSI RS Wagon
    (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
    Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
  7. #107
    Jun 2016
    Quote Originally Posted by Spinifex View Post
    The 1st mod is a throttle mod, the 2nd is a diff setting (PP or R) and the 3rd is to let the diff do the work not the abs/brakes.
    The xdl on strong feels way better imo, but I understand that the diff doesn't do much work when xdl is strong.
    Skoda RS230
    Skoda RS 230
    "The Grey Ghost"
    SG-TP-AB RS230 - Timeline
  8. #108
    Jan 2019
    Melbourne, Victoria
    Modifications
    For me the modifications I am interested in are all about improving drivability (IMO). Sharpening throttle response, increasing drive to the rear and reducing the amount of braking used by the XDL will help me get a little more out of my car. If I don't like it, I will just revert the changes one at a time to find my preferred settings
  9. #109
    Sep 2016
    Quote Originally Posted by HPRS230 View Post
    I realise that - I was questioning how something in steering can affect throttle?
  10. #110
    Jan 2019
    Melbourne, Victoria
    Wink
    I guess that is a question for VW . I made the change this morning in Module 44 Steering Assistance. Got to say, the change is very subtle.
