Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 152
Thread: OBDEleven - The new kid on the block!
  1. #51
    Pacific Paradise QLD
    Quote Originally Posted by Spinifex View Post
    Hi Don,
    Thanks for feedback. Apologies I haven't responded sooner - unfortunately, this forum doesn't seem to work the same as previous forums I've been on, in that I don't get an automatic page showing my subscribed threads that have been responded to... I have to go searching through my profile settings to load my subscribed posts... and I didn't realise anyone had made any further posts in here (or am I doing it wrong?)
    Adjustable here
    Set subscription mode to instant email
  2. #52
    Apr 2015
    Thanks Don,
    What I didnt really want to hear, , not the last disappointment that I will face I suspect, .
    Found the adaptor kit at VW central for AU$200, need to work out if I want them that much.
    Thanks again for the speedy response Don
  3. #53
    Jan 2010
    Brisbane - QLD
    Hey Stewie, is not the "pace car" indicator adaptation "close enough" to what you want? Especially at zero cost to programme using either OBD11 or VCDS.
    VCDS (VAG-COM) codes and programmable options for Golf Mk7 - post courtesy of Don (DV52) again, thanks to Don for all your work!
    Current drive:2016 Golf GTI 40 Years in Pure White
  4. #54
    Apr 2015
    Hi Brian,
    All for the zero cost option, ., ill take a look, thanks Brian and Don again.
    Stu
  5. #55
    Jul 2009
    The Gap, Queensland
    Hope this isn't off-topic folks.
    I have a 2012 T5.1 Transporter and am considering buying the OBDeleven with dongle.
    Would OBDeleven allow me access to the Distance Impulse Number on my vehicle? I would like to calibrate the speedometer for new tyres/rims. I can increase the sizes in Queensland (within ADR limits) IF the speedometer is also within ADR limits. This means I need to "recalibrate" the speedometer. As I understand things, a GPS "speedo" is not acceptable to the law so the instrument panel needs to be accurate.
    If anyone has a comment here I'd appreciate it - or if there are pointers to posts where people have made the DIN changes. I DO understand that this can be done on some sedans, at least.
    Thanks in advance.
  6. #56
    Quote Originally Posted by transparu View Post
    Thanks in advance.
    transaru: I assume that you will want to alter Byte 0, Bit0-3 in the Instrument control module (@ address hex17) as shown below using VCDS
    I suspect that OBD11 will be able to do this (if you buy the PRO unit), but you need to understand that it does things a little different to VCDS. OBD11 doesn't have a long coding helper screen, so you won't be able to change Bit 0-3 in one operation like VCDS. You probably will need to change each individual Bit and I suspect that you will need to "interpret" the meaning of each Bit.
    But it should be doable - I reckon
  7. #57
    Apr 2015
    Thought id chime in and say i used my OBDeleven Pro to help install a GTI paddle shift steering wheel into my Jetta. Was great to use and the backup function gave me a lot of 'piece of mind', as this was my first time delving into mods that needed codding to work.
    I originally got OBDeleven for diagnostics as i was having a few issues with numerous intermittent CEL's, and having an in depth VAG-specific look at things really help sort out the issues i was having. Highly recommend anyone new to the VAG game to get themselves one. Great help for diagnostics, but also has lots of awesome coding mods for the newer generations ( MK7 etc)
  8. #58
    Jul 2009
    The Gap, Queensland
    Don,
    Thanks so much for this. You give me a little more confidence that this is the route to go. A pity there is no one around here in Brisbane I can see who has a VCDS I can use to look at my car.
    I'll be sure to put any experience I gain up on the forum.
    Dave
  9. #59
    Sep 2016
    ........ A pity there is no one around here in Brisbane I can see who has a VCDS I can use to look at my car.........
    Hey Dave - there's a few of us around with either OBD11 or VCDS cables/programs here in Brissy.
    If you can make it, come along to the happy laps at Willowbank
    VW Queensland Raceway Breakfast and Laps April 9th,
    then join us for a cruise/get-together afterwards
    Social Drive Days in SE Qld.
    I'm sure we can bring our various cables and dongles, etc and have a look at your car for you.
    Great way to meet some like-minded enthusiasts too.
    There's no cost for either event - just $20 if you want to go to happy laps and enjoy the provided canteen breakfast, but that's a sharp 7am start.
    2016 Skoda Octavia 162TSI RS Wagon
    (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
    Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
  10. #60
    Jul 2009
    The Gap, Queensland
    Thanks Spinifex - I must say I hadn't heard of the Raceway event, though I'm tied up this weekend.
    I do appreciate the info and will keep my eyes open for future such activities.
    Dave
