Thanks Don,
What I didnt really want to hear, , not the last disappointment that I will face I suspect, .
Found the adaptor kit at VW central for AU$200, need to work out if I want them that much.
Thanks again for the speedy response Don
Adjustable here
Set subscription mode to instant email
Thanks Don,
Hey Stewie, is not the "pace car" indicator adaptation "close enough" to what you want? Especially at zero cost to programme using either OBD11 or VCDS.
VCDS (VAG-COM) codes and programmable options for Golf Mk7 - post courtesy of Don (DV52) again, thanks to Don for all your work!
Current drive:2016 Golf GTI 40 Years in Pure White
Hi Brian,
All for the zero cost option, ., ill take a look, thanks Brian and Don again.
Stu
Hope this isn't off-topic folks.
I have a 2012 T5.1 Transporter and am considering buying the OBDeleven with dongle.
Would OBDeleven allow me access to the Distance Impulse Number on my vehicle? I would like to calibrate the speedometer for new tyres/rims. I can increase the sizes in Queensland (within ADR limits) IF the speedometer is also within ADR limits. This means I need to "recalibrate" the speedometer. As I understand things, a GPS "speedo" is not acceptable to the law so the instrument panel needs to be accurate.
If anyone has a comment here I'd appreciate it - or if there are pointers to posts where people have made the DIN changes. I DO understand that this can be done on some sedans, at least.
Thanks in advance.
transaru: I assume that you will want to alter Byte 0, Bit0-3 in the Instrument control module (@ address hex17) as shown below using VCDS
I suspect that OBD11 will be able to do this (if you buy the PRO unit), but you need to understand that it does things a little different to VCDS. OBD11 doesn't have a long coding helper screen, so you won't be able to change Bit 0-3 in one operation like VCDS. You probably will need to change each individual Bit and I suspect that you will need to "interpret" the meaning of each Bit.
But it should be doable - I reckon
Thought id chime in and say i used my OBDeleven Pro to help install a GTI paddle shift steering wheel into my Jetta. Was great to use and the backup function gave me a lot of 'piece of mind', as this was my first time delving into mods that needed codding to work.
I originally got OBDeleven for diagnostics as i was having a few issues with numerous intermittent CEL's, and having an in depth VAG-specific look at things really help sort out the issues i was having. Highly recommend anyone new to the VAG game to get themselves one. Great help for diagnostics, but also has lots of awesome coding mods for the newer generations ( MK7 etc)
Don,
Thanks so much for this. You give me a little more confidence that this is the route to go. A pity there is no one around here in Brisbane I can see who has a VCDS I can use to look at my car.
I'll be sure to put any experience I gain up on the forum.
Dave
Hey Dave - there's a few of us around with either OBD11 or VCDS cables/programs here in Brissy.
If you can make it, come along to the happy laps at Willowbank
VW Queensland Raceway Breakfast and Laps April 9th,
then join us for a cruise/get-together afterwards
Social Drive Days in SE Qld.
I'm sure we can bring our various cables and dongles, etc and have a look at your car for you.
Great way to meet some like-minded enthusiasts too.
There's no cost for either event - just $20 if you want to go to happy laps and enjoy the provided canteen breakfast, but that's a sharp 7am start.
2016 Skoda Octavia 162TSI RS Wagon
(Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
Thanks Spinifex - I must say I hadn't heard of the Raceway event, though I'm tied up this weekend.
I do appreciate the info and will keep my eyes open for future such activities.
Dave
