Originally Posted by
Ryan_R
Same issues here mate. Worked fine the first time but the app has had 2 updates since (throwing in more ads, yay) and has basically timed out on all screens when attempting to connect.
Would be great if they rolled back the app version while they find a fix.
Ryan: I've also had a couple of updates, but I hadn't done an scan since. So I just tried a short time ago with the latest version of the App loaded and it completed the scan (14 x control modules) in about 2 minutes (see results below - I started the scan at 1400 hrs). So - I'm not sure that the App version is to blame (well, not for my mk7 in any event).
As you will be aware, there appears to be lots of to-and-fro data messaging over the net when anything happens with OBD11 (including scans). And clearly the size of the cache on the tablet/mobile-phone will also be a factor. But there is no doubt about it - OBD11 is much slower than my trusty HEX-NET and it's invariably also much slower than even my HEX+CAN cable! But then you can't expect superlative performance when you pay a petty-cash price!!
Code:
Date: 2016-12-15 14:02
VIN: #############
Car: Volkswagen Golf
Year: 2013
Engine: CHPA
Mileage: 26205 KM
01 Engine Control Module 1
System description: 1,4l R4 TSI
Software number: 04E906016G
Software version: 7862
Hardware number: 04E907309A
Hardware version: H08
ODX name: EV_ECM14TFS01104E906016G
ODX version: 002011
Long coding: 01250032242405082000
Trouble codes:
No trouble codes found
02 Transmission Control Module
System description: GSG DQ200-MQB
Software number: 0CW300045
Software version: 5240
Hardware number: 0AM927769G
Hardware version: H43
Serial number: CU501212296246�
ODX name: EV_TCMDQ200021
ODX version: 001001
Long coding: 0014
Trouble codes:
03 Brakes 1
System description:ESC
Software number: 5Q0907379AC
Software version: 0437
Hardware number: 5Q0907379D
Hardware version: H75
Serialnumber:
ODX name: EV_Brake1UDSContiMK100IPB
ODX version: 008020
Long coding:01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
Trouble codes:
08 Air Conditioning
System description: Climatronic
Software number: 5G0907044Q
Software version: 0503
Hardware number: 5G0907044Q
Hardware version: H02
ODX name: EV_ACClimaBHBVW37X
ODX version: 002017
Long coding: 00120004200100011005004012101800
Trouble codes:
09 Central Electrics
System description: BCM MQBAB M
Software number: 5Q0937084N
Software version: 0106
Hardware number: 5Q0937084N
Hardware version: H14
Serial number: 00011234701612
ODX name: EV_BCMCONTI
ODX version: 010001
Long coding:03001842C24102FB0FA4400000040308100A000000000000000000000000
Subsystems:
System description:WWS 121120
Software version: 0551
Hardware version: 042
Serialnumber: 121206042218
Long coding: 0E4DD5
System description:RLFS
Software version: 0042
Hardware version: 024
Serial number: Y13M01D03H20M05S37S1
Long coding: 00A8DD
Trouble codes:
15 Airbag
System description: AirbagVW20
Software number: 5Q0959655C
Software version: 0361
Hardware number: 5Q0959655C
Hardware version: 011
Serial number: 003F5R01UHNZ
ODX name: EV_AirbaVW20SMEVW37X
ODX version: 002126
Long coding: 98CCC000000000005C00000000C800000065
Subsystems:
System description: SideSensor_Df
Software version: 0887
Hardware version: 001
Serial number: 357670000007612C7C0W
Long coding: 2D2D2D
System description: SideSensor_Pf
Serial number: 358670000006332C7C0V
Long coding: 2D2D2D
System description: SideSensor_Dr
Software version: 6149
Serial number: 3516502AF0CD5EC471C+
Long coding: 2D2D2D
System description: SideSensor_Pr
Serial number: 3526502B30CD5EC2136J
Long coding: 2D2D2D
System description: FrontSensor_D
Serial number: 3556502B30CD5EC4008M
Long coding: 2D2D2D
Trouble codes:
16 Steering Column Electronics
System description: Lenks. Modul
Software number: 5Q0953507AE
Software version: 0070
Hardware number: 5Q0953549A
Hardware version: 007
Serial number: 08011304220489
ODX name: EV_SMLSKLOMQB
ODX version: 009001
Long coding: 0500
Trouble codes:
17 Dash Board
System description:KOMBI
Software number: 5G0920860
Software version: 0555
Hardware number: 5G0920860
Hardware version: 235
ODX name: EV_DashBoardVDDMQBAB
ODX version: 008026
Long coding: 27A501082380800801087E00040000
Trouble codes:
19 Gateway
System description: GW MQB Mid
Software number: 5Q0907530E
Software version: 1109
Hardware number: 5Q0907530E
Hardware version: 121
Serial number: 0000188941
ODX name: EV_GatewLear
ODX version: 006010
Long coding:030100342B086400EF0006481C0F00010001000000000000000000000000
Subsystems:
System description: J367-BDMHella
Software version: 8042
Hardware version: H03
Serial number:3451678601
System description: E221__MFL-DC1
Software version: 0035
Hardware version: H13
Serial number: 02120005290300060291
Long coding: 280000
Trouble codes:
42 Door Electronics Driver Side
System description: TSGFS
Software number: 5Q4959593
Software version: 0006
Hardware number: 5Q4959593
Serial number: 0000046453458
ODX name: EV_DCUDriveSideEWMAXCONT
ODX version: 006001
Long coding: 003A02208001020000001000
Subsystems:
System description: Fond FHSG DRV
Software version: 0002
Serial number: 00000000000000502227
Long coding: 0D0000
Trouble codes:
44 Steering Assistance
System description: EPS_MQB_ZFLS
Software number: 5Q0909144L
Software version: 1021
Hardware number: 5Q0909144L
Hardware version: 119
ODX name: EV_SteerAssisMQB
ODX version: 008022
Long coding: 01
Trouble codes:
52 Door Electronics Passenger Side
System description: TSG BFS
Software number: 5Q4959592
Hardware number: 5Q4959592
Serial number: 0000048027940
ODX name: EV_DCUPasseSideEWMAXCONT
ODX version: 006001
Long coding: 003A00208E01020000801000
Subsystems:
System description: Fond FHSG PSG
Serial number: 00000000000000502825
Long coding: 050000
Trouble codes:
5F Information Control Unit 1
System description: MU-S-N-ER
Software number: 5G0035846A
Software version: 0486
Hardware number: 5G0035846
Hardware version: 039
Serial number: V1F00501130081
ODX name: EV_MUStd4CPASE
ODX version: 002039
Long coding:02730008FF00000011510001000900001F0104960100010047
Subsystems:
System description:ABT_Std_Nav
Software version: 0022
Hardware version: H44
Serial number:VWZ8Z9M3400KZM
System description: ROW2016
Software version: 0034
Hardware version: ---
Serial number: --------------------
Trouble codes:
B200500 - Data record invalid
static
76 Parking Assistance
System description: PARKHILFE 8K
Software number: 5Q0919294B
Software version: 0026
Hardware number: 5Q0919294A
Hardware version: 002
Serial number: 94231233000504
ODX name: EV_EPHVA18AU3700000
ODX version: 002016
Long coding: 0031151011
Trouble codes:
