Page 5 of 16 FirstFirst ... 3456715 ... LastLast
Results 41 to 50 of 152
Thread: OBDEleven - The new kid on the block!
  1. #41
    Apr 2010
    Same issues here mate. Worked fine the first time but the app has had 2 updates since (throwing in more ads, yay) and has basically timed out on all screens when attempting to connect.
    Would be great if they rolled back the app version while they find a fix.
  2. #42
    Ryan: I've also had a couple of updates, but I hadn't done an scan since. So I just tried a short time ago with the latest version of the App loaded and it completed the scan (14 x control modules) in about 2 minutes (see results below - I started the scan at 1400 hrs). So - I'm not sure that the App version is to blame (well, not for my mk7 in any event).
    As you will be aware, there appears to be lots of to-and-fro data messaging over the net when anything happens with OBD11 (including scans). And clearly the size of the cache on the tablet/mobile-phone will also be a factor. But there is no doubt about it - OBD11 is much slower than my trusty HEX-NET and it's invariably also much slower than even my HEX+CAN cable! But then you can't expect superlative performance when you pay a petty-cash price!!
    Code:
    Date: 2016-12-15 14:02
        VIN: #############
        Car: Volkswagen Golf
        Year: 2013
        Engine: CHPA
        Mileage: 26205 KM
    01 Engine Control Module 1
        System description: 1,4l R4 TSI
        Software number: 04E906016G
        Software version: 7862
        Hardware number: 04E907309A
        Hardware version: H08
        ODX name: EV_ECM14TFS01104E906016G
        ODX version: 002011
        Long coding: 01250032242405082000
        Trouble codes:
            No trouble codes found
    02 Transmission Control Module
        System description: GSG DQ200-MQB
        Software number: 0CW300045
        Software version: 5240
        Hardware number: 0AM927769G
        Hardware version: H43
        Serial number: CU501212296246
        ODX name: EV_TCMDQ200021
        ODX version: 001001
        Long coding: 0014
        Trouble codes:
    03 Brakes 1
        System description:ESC
        Software number: 5Q0907379AC
        Software version: 0437
        Hardware number: 5Q0907379D
        Hardware version: H75
        Serialnumber:
        ODX name: EV_Brake1UDSContiMK100IPB
        ODX version: 008020
        Long coding:01FA8AA1202312700377060701C32980510448C0608094F3002A0028C1
        Trouble codes:
    08 Air Conditioning
        System description: Climatronic
        Software number: 5G0907044Q
        Software version: 0503
        Hardware number: 5G0907044Q
        Hardware version: H02
        ODX name: EV_ACClimaBHBVW37X
        ODX version: 002017
        Long coding: 00120004200100011005004012101800
        Trouble codes:
    09 Central Electrics
        System description: BCM MQBAB M
        Software number: 5Q0937084N
        Software version: 0106
        Hardware number: 5Q0937084N
        Hardware version: H14
        Serial number: 00011234701612
        ODX name: EV_BCMCONTI
        ODX version: 010001
        Long coding:03001842C24102FB0FA4400000040308100A000000000000000000000000
        Subsystems:
            System description:WWS    121120
            Software version: 0551
            Hardware version: 042
            Serialnumber:         121206042218
            Long coding: 0E4DD5
            System description:RLFS
            Software version: 0042
            Hardware version: 024
            Serial number: Y13M01D03H20M05S37S1
            Long coding: 00A8DD
        Trouble codes:
    15 Airbag
        System description: AirbagVW20
        Software number: 5Q0959655C
        Software version: 0361
        Hardware number: 5Q0959655C
        Hardware version: 011
        Serial number: 003F5R01UHNZ
        ODX name: EV_AirbaVW20SMEVW37X
        ODX version: 002126
        Long coding: 98CCC000000000005C00000000C800000065
        Subsystems:
            System description: SideSensor_Df
            Software version: 0887
            Hardware version: 001
            Serial number: 357670000007612C7C0W
            Long coding: 2D2D2D
            System description: SideSensor_Pf
            Serial number: 358670000006332C7C0V
            Long coding: 2D2D2D
            System description: SideSensor_Dr
            Software version: 6149
            Serial number: 3516502AF0CD5EC471C+
            Long coding: 2D2D2D
            System description: SideSensor_Pr
            Serial number: 3526502B30CD5EC2136J
            Long coding: 2D2D2D
            System description: FrontSensor_D
            Serial number: 3556502B30CD5EC4008M
            Long coding: 2D2D2D
        Trouble codes:
    16 Steering Column Electronics
        System description: Lenks. Modul
        Software number: 5Q0953507AE
        Software version: 0070
        Hardware number: 5Q0953549A
        Hardware version: 007
        Serial number: 08011304220489
        ODX name: EV_SMLSKLOMQB
        ODX version: 009001
        Long coding: 0500
        Trouble codes:
    17 Dash Board
        System description:KOMBI
        Software number: 5G0920860
        Software version: 0555
        Hardware number: 5G0920860
        Hardware version: 235
        ODX name: EV_DashBoardVDDMQBAB
        ODX version: 008026
        Long coding: 27A501082380800801087E00040000
        Trouble codes:
    19 Gateway
        System description: GW MQB Mid
        Software number: 5Q0907530E
        Software version: 1109
        Hardware number: 5Q0907530E
        Hardware version: 121
        Serial number: 0000188941
        ODX name: EV_GatewLear
        ODX version: 006010
        Long coding:030100342B086400EF0006481C0F00010001000000000000000000000000
        Subsystems:
            System description: J367-BDMHella
            Software version: 8042
            Hardware version: H03
            Serial number:3451678601
            System description: E221__MFL-DC1
            Software version: 0035
            Hardware version: H13
            Serial number: 02120005290300060291
            Long coding: 280000
        Trouble codes:
    42 Door Electronics Driver Side
        System description: TSGFS
        Software number: 5Q4959593
        Software version: 0006
        Hardware number: 5Q4959593
        Serial number: 0000046453458
        ODX name: EV_DCUDriveSideEWMAXCONT
        ODX version: 006001
        Long coding: 003A02208001020000001000
        Subsystems:
            System description: Fond FHSG DRV
            Software version: 0002
            Serial number: 00000000000000502227
            Long coding: 0D0000
        Trouble codes:
    44 Steering Assistance
        System description: EPS_MQB_ZFLS
        Software number: 5Q0909144L
        Software version: 1021
        Hardware number: 5Q0909144L
        Hardware version: 119
        ODX name: EV_SteerAssisMQB
        ODX version: 008022
        Long coding: 01
        Trouble codes:
    52 Door Electronics Passenger Side
        System description: TSG BFS
        Software number: 5Q4959592
        Hardware number: 5Q4959592
        Serial number: 0000048027940
        ODX name: EV_DCUPasseSideEWMAXCONT
        ODX version: 006001
        Long coding: 003A00208E01020000801000
        Subsystems:
            System description: Fond FHSG PSG
            Serial number: 00000000000000502825
            Long coding: 050000
        Trouble codes:
    5F Information Control Unit 1
        System description: MU-S-N-ER
        Software number: 5G0035846A
        Software version: 0486
        Hardware number: 5G0035846
        Hardware version: 039
        Serial number: V1F00501130081
        ODX name: EV_MUStd4CPASE
        ODX version: 002039
        Long coding:02730008FF00000011510001000900001F0104960100010047
        Subsystems:
            System description:ABT_Std_Nav
            Software version: 0022
            Hardware version: H44
            Serial number:VWZ8Z9M3400KZM
            System description:  ROW2016
            Software version: 0034
            Hardware version: ---
            Serial number: --------------------
        Trouble codes:
            B200500 - Data record invalid
                static
    76 Parking Assistance
        System description: PARKHILFE 8K
        Software number: 5Q0919294B
        Software version: 0026
        Hardware number: 5Q0919294A
        Hardware version: 002
        Serial number: 94231233000504
        ODX name: EV_EPHVA18AU3700000
        ODX version: 002016
        Long coding: 0031151011
        Trouble codes:
  3. #43
    Apr 2010
    I've not tried to do a scan, just access a control module or a few of their 'apps' - comparatively small/simple operations. After waiting 3 minutes I kill the app. Outside with great 4G Internet reception, and have tried with WiFi.
    I've seen others on their forums raise similar issues.
  4. #44
    Jan 2012
    Mine sometimes freezes up either performing a task like opening up modules or scanning. I've found if my wifi is running slow can sometimes slow it down or if I'm too far away so weak wifi signal. I need no kids using the internet and not sat in the car while using it.
    2015 Golf R. Lapiz Blue.
  5. #45
    Sep 2016
    I can't assist with anyone's slow connection/scanning speeds - only to comment that I know my app has updated twice in the last few weeks, and while quite slow to scan, I still manage to scan the full system usually within 2 or 3 minutes.
    So I doubt it has anything to do with the app itself having problems, but probably a case of internet-signal being dodgy (despite what your device shows to be "good 4G signal strength)
    2016 Skoda Octavia 162TSI RS Wagon
    (Race Blue, DSG, Tech pack, Comfort pack, 18" Black pack, panoramic sunroof, auto tailgate)
    Previous: 2012 Mazda 6 Diesel // 2001 Subaru Liberty STi // 1991 Subaru Liberty RS Turbo // VK Holden Commodore // Subaru Leone // Mazda RX-808 // Mitsubishi Magna // 1971 Mazda R100 Coupe
  6. #46
    Sep 2016
    Spinifex............Another option might be to search through the "engineering menu" in the MIB unit for a similar facility......
    Hi Don,
    Thanks for feedback. Apologies I haven't responded sooner - unfortunately, this forum doesn't seem to work the same as previous forums I've been on, in that I don't get an automatic page showing my subscribed threads that have been responded to... I have to go searching through my profile settings to load my subscribed posts... and I didn't realise anyone had made any further posts in here (or am I doing it wrong?)
    I've enabled the engineering menu on my car some time ago, but honestly didn't really understand much of it. I didn't have much of a poke around, as it didn't make much sense, and from memory, it didn't have the same "return button" to return to the previous menu, as the main MIB system, so I couldn't work out how to go back through the screens - I seemed to have to close & then re-start the engineering menu from scratch every time I wanted to look at something different.
    Will have more of a play around again and see if I can identify anything.
  7. #47
    Sep 2016
    Question: I've used the one-click app (only cost 10 credits, and I haven't seen the long-coding for this listed anywhere) to enable the "automatic lock doors if key is outside vehicle" function.
    However - it's WAAAYYYY too quick to do so.
    I've barely closed the door and set both feet on the ground (with the key either in my pocket or hand) and the car is already locking the doors.
    While this is the intended purpose, I'd like to delay the time-frame of locking to something more realistic, like 10 seconds, or a particular distance away from the car.
    Does anyone know the long-coding parameters I need for this?
    Eg: the auto-locking is SO instant, that it's instantly locked and mirrors-folded, when I close the drivers door - yet my passengers haven't even opened their doors to get out yet!
    Also makes getting out of the car and going to the boot a frustration, as it's locked before I get to the back of the car.
    If I could set a longer time, or something like 10m away from car, before locking occurs, this would be much more realistic.
    Any and all help appreciated.
  8. #48
    Hi Golferos!
    I declined the promise on my private profile in ClubVWGolf!
    XaGiCo - 2.0 TDI 150 CV Sport R Line 4Motion - 2014 - Ponferrada
    Club VW Golf España
    Quote Originally Posted by XaGiCo View Post
    GOLF 2017 en mi MIB2
    En unos días compartiré la codificación y requisito, en su sitio!
    Club VW Golf España
    Golf 2017
    Golf GTI 2017
    Saludos :secta:
    Cambiar a Pantallas a Golf 2017 o Golf GTI 2017Switch to Screens for Golf 2017 or Golf GTI 2017
    MIB2 requirement as of version 8XX
    ONLY CODING WITH OBDELEVEN /ODIS / VCP
    1) 5F - Information Electronic
    2) Coding
    Byte 02
    CAR DERIVATE SUPPLEMENT
    1
    HEX
    10
    BINARY
    00010000
    Thanks @Zloybob
    Next Version PDF 1.5 in Last week of January 2017
    Regards and Happy New Year 2017 !!
    XaGiCo
  9. #49
    Apr 2015
    Hi All, Got an ODBeleven last week, got the app, got it connected and then put it aside over the break as to many other things on. Picked it up this morning and had a fiddle, neat thing. Turned on the TMC as walked through by DV52 back on page three of this thready, worked a treat, ill be interested how it works when I can get out on the road with it. I am also interested in coding Dynamic LED Indicators on the MkVII Golf R, like this:
    https://www.youtube.com/watch?v=hCSDuiTwsY0
    Is this possible?
    Thanks in anticipation,
  10. #50
    Quote Originally Posted by Stewiefly16 View Post
    Is this possible?
    Stewie: Ironically the very next video after the one that you posted answers your question (see below)!!!
    Alas, "Leuchte programming" isn't able to provide a delay between the inner/outer lights as shown in your video. With coding, you can have counter-blinking turn signals, or synchronous blinking turn signals.
    The effect that is in the video is achieved by adding a separate piece of hardware (and an adapter cable). So no coding needed - just hardware
