Results 21 to 30 of 152
Thread: OBDEleven - The new kid on the block!
Threaded View
    I've been playing around with an OBDEleven (OBD11) device and I thought that I would share my observations with anyone who has an interest! My synopsis of the OBD11 is mainly in picture form!
    OBD11 is a new diagnostic tool, but it uses a different architecture to the more established diagnostic tools like VCDS and VCP. Perhaps the major difference is the fact that ODB11 operates on an Android platform (version 4.1, or greater is needed) and it is an App. In my case, I went-out and purchased a cheap Lenova 7 inch tablet which ran Android 4.2.2 (less than $100)
    Rather than the operating software being loaded onto a local laptop, only a small portion of the OBD11 software is resident locally and the database is accessed at OBD11 HQ via the internet. This means that a good internet connection is crucial to operate the device successfully. There is no cable between the dongle that fits over the OBD socket and the tablet/mobile phone on which the App is loaded - the connection between the two is via Bluetooth. Here's a picture of the dongle
    Not having a cable connected dongle is great - I can sit comfortably outside the vehicle and do all the programming at the workbench!
    Once the dongle is delivered, the first task is to pair the Bluetooth dongle with the tablet/mobile phone - easy enough with the Lenovo tablet (the PIN is 12345). After the dongle was successfully paired, and the OBD11 App is opened for the first time, the user must create a Google account, the details of which are used to register the user with OBD11 HQ and the device can then be used in earnest!
    Here's a Picture of the main screen (after the tablet is connected to the dongle)
    Pressing the "blue circle" at the lower RHS of the picture above gives the user access to a list of the control modules in the car (after the car is scanned)
    In the following picture, I selected the "Central Electronics" module in the screen-shot above. The screen below is the Main Screen from which a number of subsequent screen shots below are sourced
    Selecting "Advanced information" from the Main Screen produces the following:
    Selecting the "Security access" from the Main Screen gives the following:
    Selecting "Adaptation" in the main screen produces a list of the "Parent" adaptation channels in the control module (unlike VCDS which produces a flat list of both parent and child adaptation channels. Like VCP, the user is then able to choose from the Parent list by typing-in the relevant details. In the screen shot below I was looking for "LeuchteBR20 LA71" which is the rear outer taillight - so I typed "la".
    Selecting Leuchte20BR LA71 gives the following list of "Child" adaption channels:
    Selecting the Lichtfunkion B20 adaptation channel in the screen above gives a list of the possible settings as below
    Selecting "Long Coding" from the Main Screen gives the following
    From this screen it is also possible to access individual Bytes as per the picture below
    selecting "Basic Settings" from the Main Screen gives the following
    The following are random screens shots that hopefully give a "flavour" of the other capabilities of the device
    OBD11 has a number of "Pre-canned" Tweaks for the mk7 - some of which are shown in the screen shot below
    The user can also access a "Blog" via the software
    I got the "PRO" unit so I can make changes to long coding, but those considering a purchase should acquaint themselves with the differences between the two models (I'm still trying to get my head around how these work).
    I've been playing with this device for about two weeks, and I must say that I'm surprised at its versatility. It certainly has its disadvantages, but it does some functions better than VCDS (IMO). For example, a disadvantage of OBD11 is that it currently can't access slave control modules (like the RLS/RLHS/RLFS) - note: this has since changed for VCDS. An advantage is that with OBD11, the user can make changes to a number of adaptation channels from the one screen. Of course the other advantage of OBD11 is the price -Very inexpensive
    PS: Notwithstanding my good experience with OBD11, VCDS is still my go-to cable of choice. Just can't beat VCDS's intuitive software, its up-to-date database and it's ease of use - well done Uwe Ross!! Nevertheless, if you are after an inexpensive device with legitimate IP and with the potential for better functionality over time, then OBD11 is worth a look (IMO)
    Last edited by DV52; 16-02-2018 at 08:38 AM. Reason: Don't know my OBDs from my ODBs! - Thanks Adam
