Your coding for the comfort blinkers were spot on Hillbilly, and I've been able to tick that one off the list. Was set for 5, now a much more sensible 2. Thanks for that!
But these others remain elusive:
Auto Close Windows When Raining:
Select Control unit 09 (Central Electrics)
Security access
Access code 31347
Adaptation
(15) Access Control 2-Regenschliessen_ein_aus -
Nope, doesn't appear anywhere in the list ODB11 brings up
Value: Permanent
(16) Access Control 2-Regenschliessen_art -
Again, doesn't appear anywhere in the list ODB11 brings up
Value: Permanent
(2
![Cool](https://www.vwwatercooled.com.au/forums/images/smilies/icon_cool.gif)
Zugriffskontrolle 2-Menuesteuerung Regenschliessen -
Yet again, doesn't appear anywhere in the list. Aborting...
Value:Aktif
Control unit Long Coding
Subsystem: Rain / Light Sensor (RLS)
Byte 0
Bit 1-Bit 2 DeActivate
Traffic Sign Assist Activation (Car must be fitted with Camera -
yep, it is )
Select Control unit 5F (Information Electrical -
OBDeleven names this something else, but whatever... unit 5F seems definitive enough to cautiously carry on with)
Adaptation
Select channel (63) vehicle function list BAP traffic_sign_recognition_0x21 -
Değer=Active
Select channel (151) vehicle menu operation-menu_display_road_sign_identification -
Nope. Sigh, I give up.
Değer=Active
Select channel (153) vehicle menu operation-menu_display_road_sign_identification_over_thresho ld_high
Değer=Active
Control unit A5 (front / advance camera)
Security access
Access Code 20103
Byte 1
Bit 0 Activate – “01 Traffic Sign Recognition (FTE) active”
Select Control unit 17 (Dashboard)
Byte 5
Bit 2 Aktivate
Adaptation
Select : channel numbers indicate end of speed limit
Importance to actively invest Show Valid suffix
View Channel Valid suffix
Corresponding value adjust default: 00100111
High Beam Assist (for cars with Lane Assist Camera -
yes we have that):
Ensure light switch is in the OFF position, wipers not on auto, doors closed and ignition on, before starting.
OK, noted.
1. Select Control unit 09 (Central Electrics)
2. Control unit Long Coding
3. Byte 02
4. Bit 0-2: "03 Lighting Bi-Xenon with Light Assist"
5. Select Control unit 09 (Central Electrics)
6. Security Access Code: 31347
7. Adaptation
8. Assistance Light Functions - Menuestuerung Fernlichtassistent -
one last try... nope, doesn't appear in the list. Arrgh! I'm really giving up at this point.
9. New Value: Present
10. Assistance Light Functions - Menuestuerung Fernlichtassistent Werkseinstellung
11. New Value: Present
12. Select Control unit A5
13. Security Access Code: 20103
14. Control unit Long Coding
15. Byte 02
16. Bit 0-7: "01 coding_Light/High_beam_assist"
Optional settings
17. Controller A5
18. Speed that HBA active set to 20kph
19. Speed that HBA deactivate set to 10kph
20. Change lux code to 10
Perhaps all these adaptation descriptors are out of date? Or OBDeleven is hiding some descriptors? Or PEBKAC error?
