for other people....if you have a older red display dash turn off sat nav BAP setting with VCDS and then it will work on your dash red display...only the white displays use BAP...VDUB...
Hey all I recently updating my maps on my RNS-510 and everything seems to be ok however recently I noticed that the little N,S,E,W displays aren't appearing on my MFD as well as the direction display when using Maps?
I have gone into Can-Gateway and installed 37 Navigation and have also checked the navigation coding but can't see anything for the life of me that relates to cluster display or navigation display on MFD?
Is there something related to BAP that I'm missing?
I don't have a Dynoaudio installed it's just a standard audio system...
Please help...
Thanks
Delete got it sorted
GOLF GTI MY11 ADIDAS Candy White, Sunroof
GOLF GTI 40th ED, White with Sunroof
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
I am having the same problem after I updated firmware on my 2010 Tiguan with white MFD, can some one point me in the right direction what the coding is altered on vcds please.
Mick
2018 Tiguan SEL 2.0TSI DSG dressed in deep black pearl. 2010 EOS SE 2.0TDI DSG Full leather, Retro fitted RNS510 OE Blue tooth and Media unit in glove box, 35 mm drop and running on 18,s.
