Bluetooth is now working with the code 412120, pretty disappointed with the 9w2, think it will be going in the bin for a 9w7. Ops is still not responding though
hi guys
i have just installed a oem bluetooth and 4 sensor rear park assist from forum diy's.
have now come to code it with vcds and can't get either to function at all.
car is a 09 mk5 gti
head unit is rns 510 gps
the soft code for the telephone is :312120
the park/steering assist menu is activated on canbus but it pops up with an error and cant access it.
here is the error report:
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 0010
Address 10: Park/Steer Assist
Cannot be reached
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
Component: J0527 752 0101
Coding: 0012122
Shop #: WSC 00046 412 00000
VCID: 840D12C9C700BE9
Part No: XXXXXXXXXXX
Component: E0221 002 0010
1 Fault Found:
01299 - Diagnostic Interface for Data Bus (J533)
004 - No Signal/Communication - Intermittent
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 020708F2000968
Coding: EDA17F0E5006020003
Shop #: WSC 30024 959 88134
VCID: 356B3F0D5C5A571
5 Faults Found:
01327 - Control Module for Parking Aid (J446)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 132316 km
Time Indication: 0
Date: 2000.00.00
Time: 02:01:06
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 132255 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 62
Mileage: 132255 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:05
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 1
Fault Frequency: 104
Mileage: 132255 km
Time Indication: 0
Date: 2000.00.00
Time: 00:00:01
03075 - Parallel Parking Assistance Control Module (J791)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 25
Mileage: 132316 km
Time Indication: 0
Date: 2000.00.00
Time: 01:54:14
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 1210
Coding: 0000692
VCID: 387536394B48AA9
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 830F11D5C20EB91
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
4 Faults Found:
00830 - Convertible Top Control Module (J256)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 63
Time Indication: 0
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 63
Time Indication: 0
00317 - Rear Lid Control Module (J605)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 63
Time Indication: 0
01517 - Control Module for Trailer/Towing Sensor (J345)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 63
Time Indication: 0
Address 76: Park Assist
Cannot be reached
Address 77: Telephone (J73 Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A10210939
Coding: 312120
Shop #: WSC 00078 790 00195
VCID: 2A511C7145E4089
5 Faults Found:
03426 - Left Audio Channel
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 7 km
Time Indication: 0
Date: 2000.14.12
Time: 06:48:39
03427 - Right Audio Channel
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 62
Mileage: 7 km
Time Indication: 0
Date: 2000.14.12
Time: 06:48:39
01524 - Antenna for Telephone
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 25
Mileage: 132316 km
Time Indication: 0
02791 - Telephone Baseplate (R126)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 25
Mileage: 132316 km
Time Indication: 0
01304 - Radio
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 62
Mileage: 7 km
Time Indication: 0
Date: 2000.14.12
Time: 06:48:42
Where are you located? If you code the park aid into the gateway and it shows error and you cant get into that control unit then make sure your powers annd earths and canbus wiring to the new installed unit is ok...VDUB..
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Cheers I will check them again at the ops unit. Is there a way to check can high and low with a multimeter?
Also what pin/ how to do add one to the fuse box? At the moment I have the wire from the ops unit wedged in with a 10 amp fuse drawing power from the top row of fuses which is switched power
If you check CAN for convienence its usually shown as about 2.5 volts.....and drivetrain CAN about 4.5 volts but really you need a scope. Check powers and earth first..
You need to find a empty fuse hole with only one pin showing with the power type you need..then going from back of fuse box insert your pin into the empty slot and fit your fuse
Thanks, is there a certain type of pin for the fuse box or will just a normal one from jaycar work?
To answer my own question, part number 000979021E repair wire about $10 each 0.5mm wire for 5-10 amp small fuse
