Results 1 to 8 of 8
Thread: need vcds help with BT and OPS!! Errors galore!!
    Mar 2014
    hi guys
    i have just installed a oem bluetooth and 4 sensor rear park assist from forum diy's.
    have now come to code it with vcds and can't get either to function at all.
    car is a 09 mk5 gti
    head unit is rns 510 gps
    the soft code for the telephone is :312120
    the park/steering assist menu is activated on canbus but it pops up with an error and cant access it.
    here is the error report:
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: Malfunction 0010
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: Malfunction 0010
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Malfunction 1010
    42-Door Elect, Driver -- Status: Malfunction 0010
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: Malfunction 0010
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    76-Park Assist -- Status: Cannot be reached 1100
    77-Telephone -- Status: Malfunction 0010
    Address 10: Park/Steer Assist
    Cannot be reached
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 BS HW: 1K0 953 549 BS
    Component: J0527 752 0101
    Coding: 0012122
    Shop #: WSC 00046 412 00000
    VCID: 840D12C9C700BE9
    Part No: XXXXXXXXXXX
    Component: E0221 002 0010
    1 Fault Found:
    01299 - Diagnostic Interface for Data Bus (J533)
    004 - No Signal/Communication - Intermittent
    Address 19: CAN Gateway Labels: 1K0-907-530.lbl
    Part No SW: 1K0 907 530 Q HW: 1K0 907 951
    Component: J533 Gateway H07 0062
    Revision: H07 01 Serial number: 020708F2000968
    Coding: EDA17F0E5006020003
    Shop #: WSC 30024 959 88134
    VCID: 356B3F0D5C5A571
    5 Faults Found:
    01327 - Control Module for Parking Aid (J446)
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 132316 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 02:01:06
    01300 - Control Module for Navigation with CD-Rom (J401)
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 62
    Mileage: 132255 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:05
    01304 - Radio
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 62
    Mileage: 132255 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:05
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 1
    Fault Frequency: 104
    Mileage: 132255 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 00:00:01
    03075 - Parallel Parking Assistance Control Module (J791)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 132316 km
    Time Indication: 0
    Date: 2000.00.00
    Time: 01:54:14
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
    Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
    Component: Tuer-SG 006 1210
    Coding: 0000692
    VCID: 387536394B48AA9
    2 Faults Found:
    01317 - Control Module in Instrument Cluster (J285)
    Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
    Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
    Component: KSG PQ35 G2 020 0204
    Revision: 00020000 Serial number: 00000000000000
    Coding: 819002005103087F2D04840570085FC690FC00
    VCID: 830F11D5C20EB91
    Part No: 1K0 951 605 C
    Component: LIN BACKUP HORN H03 1301
    Part No: 1K0 951 178 A
    Component: Neigungssensor 003 0203
    Component: Innenraumueberw.003 0203
    4 Faults Found:
    00830 - Convertible Top Control Module (J256)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    00317 - Rear Lid Control Module (J605)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    01517 - Control Module for Trailer/Towing Sensor (J345)
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 63
    Time Indication: 0
    Address 76: Park Assist
    Cannot be reached
    Address 77: Telephone (J73 Labels: 1K8-035-730.clb
    Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
    Component: Telefon H08 6900
    Revision: 00008000 Serial number: 00000A10210939
    Coding: 312120
    Shop #: WSC 00078 790 00195
    VCID: 2A511C7145E4089
    5 Faults Found:
    03426 - Left Audio Channel
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 62
    Mileage: 7 km
    Time Indication: 0
    Date: 2000.14.12
    Time: 06:48:39
    03427 - Right Audio Channel
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 62
    Mileage: 7 km
    Time Indication: 0
    Date: 2000.14.12
    Time: 06:48:39
    01524 - Antenna for Telephone
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 132316 km
    Time Indication: 0
    02791 - Telephone Baseplate (R126)
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 25
    Mileage: 132316 km
    Time Indication: 0
    01304 - Radio
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 62
    Mileage: 7 km
    Time Indication: 0
    Date: 2000.14.12
    Time: 06:48:42
    Mar 2014
    Bluetooth is now working with the code 412120, pretty disappointed with the 9w2, think it will be going in the bin for a 9w7. Ops is still not responding though
    Mar 2013
    Brisbane QLD
    Where are you located? If you code the park aid into the gateway and it shows error and you cant get into that control unit then make sure your powers annd earths and canbus wiring to the new installed unit is ok...VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Mar 2014
    Cheers I will check them again at the ops unit. Is there a way to check can high and low with a multimeter?
    Also what pin/ how to do add one to the fuse box? At the moment I have the wire from the ops unit wedged in with a 10 amp fuse drawing power from the top row of fuses which is switched power
    Mar 2013
    Brisbane QLD
    If you check CAN for convienence its usually shown as about 2.5 volts.....and drivetrain CAN about 4.5 volts but really you need a scope. Check powers and earth first..
    Mar 2013
    Brisbane QLD
    You need to find a empty fuse hole with only one pin showing with the power type you need..then going from back of fuse box insert your pin into the empty slot and fit your fuse
    Mar 2014
    Thanks, is there a certain type of pin for the fuse box or will just a normal one from jaycar work?
    Mar 2014
    To answer my own question, part number 000979021E repair wire about $10 each 0.5mm wire for 5-10 amp small fuse
