Results 1 to 10 of 13
Thread: Need help with RNS510 coding
    May 2012
    Firstly i have a MY12.5 polo GTI. I have installed my own RNS510. It is a h version built 6/2012 and has the latest firmware (4020). it all works fine but when i tried to use VCDS to enable the secret menu i had no luck. I went to
    37 navigation-adaption and changed channel 50 to 1 (was 0) igot this info from a link i found here. is this correct? as i cant get to the menu. it only allows me to see AM,FM and system info.
    Also is there any way to bring the directions from the sat nav up on the MDF like the golfs?
    And lastly how do i get the voice activation to work. if i use the steering wheel button i cant command the sat nav. but if i press the start button i cant give it commands as it seems it not connecting through the mic.
    MY16 Candy white Octavia VRS Wagon, sunroof, 19" black pack, tech pack, comfort pack, auto tail gate
    MY12.5 Polo 6R GTI
    1. That is the correct way to enable 'secret' menu
    2. You need to turn on BAP using VCDS in address 37 navigation, under coding
    3. Do you have OEM Bluetooth (was it factory installed?) If so then you need to plug the mic in the headliner into the 'mic in' + and - pins on the RNS510. THen you need to plug the bluetooth module's mic pins into the 'mic out' + and - pins on the RNS510. If you don't have OEM bluetooth then you need to plug in a mic of some sort into the mic in pins on the RNS510.
    May 2012
    I have the factory Bluetooth but not sure where it is. I'll have a look at the BAP but pretty sure it was ticked. Any ideas as to why no secret menu even though iv done the right thing?
    MY12.5 Polo 6R GTI
    Apr 2010
    Did you restart that RNS510 (push the 3 button along the top besides the Eject one).
    Illustration of required microphone wiring (genuine bluetooth retrofitted in this case):
    Even with this correct setup the steering wheel button is only used for phone functions, to voice control the sat nav you have to press the button on the RNS510.
    Aug 2011
    You'll also need to add Navigation to the Can Gateway -> Installation List along with the BAP. Make sure shortpress steering wheel is ticked too.
    It looks like the OEM BT Polos don't have the mic wiring up for the RNS from factory. It'd probably be easier to wire up a 2nd mic rather than getting a line run from the BT unit to the HU.
    Also, are you still holding the setup button after the FM menu shows? You need to keep holding for it to show.
    May 2012
    Yea I reset the unit a few times and I'm holding the button down for a whila after.
    MY12.5 Polo 6R GTI
    Aug 2011
    Quote Originally Posted by lunchboxGTI View Post
    Ah ok, I have the same unit as you but it had the 39xx firmware so I just upgraded to the modded 4020 version on the forums here.
    Did you get the navigation menu on the MFD?
    May 2012
    No going to try again this arvo.
    MY12.5 Polo 6R GTI
    May 2012
    Hey Ryan_R you picture didnt work could you please throw it up again.
    MY12.5 Polo 6R GTI
    May 2012
    So i seem to have got it working. yesterday the CAN didnt have navigation for me to tick. toaday when i started VCDS it wanted to update so i did that and when i went back in to can i could tick 37 and do the rest. i now also have the secret menu. but now i have 3 errors
    first is in the navigation saying mic is open circuit which is understandable as its not connected
    next is the radio which has the same fault
    3rd is the can which has this
    Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
    Part No SW: 6N0 909 901 HW: 6R0 937 087
    Component: GW-K-CAN TP20 H46 0254
    Revision: BF046001
    Coding: 002300
    Shop #: WSC 12469 483 00190
    VCID: F0EFE8CE23875098515
    1 Fault Found:
    01044 - Control Module Incorrectly Coded
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 2
    Fault Frequency: 1
    Time Indication: 0
    the first two i get as there is no mic connected to the RNS but is the CAN saying inccorrectly coded for the same reason or is it a separate fault? all systems seem to be going fine
    MY12.5 Polo 6R GTI
