Page 4 of 6 FirstFirst ... 23456 LastLast
Results 31 to 40 of 51
Thread: Mk6 GTI VCDS ( VAG-COM ) codes
  1. #31
    Sep 2011
    Camperdown, NSW
    Coding for telephone buttons on centre roof console
    Not sure if this is the correct place to post, but I haven't seen the information anywhere before.
    After a bit of messing around, I was able to code both buttons on the center roof console for Information (little 'i' picture) and Service/Breakdown (spanner picture) to numbers of my choosing. I now have the breakdown/service button calling VW roadside assistance and the information button calling my VW dealer.
    For those interested, under the Telephone module --> Adaption in VCDS there are four items at the bottom of the drop down list. Two for each button, one being a 'roaming' version. The Service/Breakdown coding requires 7 bytes which are entered as their raw numeric values. So for VW roadside I entered 18 00 63 71 81 00 00 (note padding with 0's for the last two bytes). The Information number requires 8 bytes, again pad with 0's for the extra bytes.
  2. #32
    May 2010
    Ipswich, Queensland
    Could not access 46 Module on MY11 Skoda vRS
    Redline3345 MY11 Octavia vRS Wagon TSI DSG | Brilliant Silver | Milltek cat back exhaust | Bilstein PSS10 | TSR Panorama | Remsa | Leather | Sunroof | Towbar | Front Sensors | Boot Protector | Xenons | Corner Fogs | Alarm | Extended Warranty | Superskoda Bits & Bling
  3. #33
    Jul 2011
    AU
    I saw a video on youtube where a guy found a code for flashing LED DRL's. If you youtube "DRL easter egg" you'll see what I mean. I would be keen to give that a try.
    One thing I would like to change is to stop the LED DRL's from dimming. When the headlight switch is on "auto" they are full brilliance, but whenever the headlights come on, or when the headlight switch is set to "park lights", the LED's dim down to about 50%. I would like them to stay at 100% at all times. Anyone know if this can be done on VCDS?
    Other VCDS mods I want to do:
    - fob window open/close
    - alarm chirp when lock/unlock
    - cluster staging
    -custom RCD510 welcome screen
    Interested to hear any other cool or even silly mods....
    ---------- Post added at 10:04 PM ---------- Previous post was at 10:02 PM ----------
    I should clarify I have an Adidas edition with the dynamic cornering xenons with LED DRL's, and the LED tail lights.
  4. #34
    Apr 2008
    For what prupose would you want your DRLs to flash like that?
    Are you aware that the DRL dimming during the indicator is a legal requirement? It's so you can spot the contrast of the indicator. I don't think you'll be bale to change that.
    The custom welcome screen is from Create your own custom bootlogo for RNS510 and you can only do it to the RNS510, not the RCD510.
    Hope that helps
  5. #35
    Jul 2011
    AU
    Quote Originally Posted by benough View Post
    Hope that helps
    My DRL's don't dim for the indicators, only when A) the headlights are on, and B) when the park lights are on.
    Are you sure that it's a legal requirement? The only cars i've seen that do that are Audi's, yet every second new car has LED DRL's these days?
  6. #36
    Sep 2009
    seaforth, nsw
    Quote Originally Posted by Tobes_WIR35 View Post
    - cluster staging
    cluster staging is already on these forums, under dancing needles.
    i always thought the key fob auto window feature was already installed. i know i can do it on my gti as i used it a lot when my car sits in the sun and i walk up to it and open the windows up before i get in
    2011 cw golf gti 3dr man-tint-rear cargo mat-weathershields-bluetooth-mdi-19" oz racing ultra leggera-mcgard lockbolts-boston acoustic pro60se-jl audio xd700/5-jl audio bass tube bb-w060p- titanium exhaust tips-eibach custom pro-kit-OPS-OSIR cf mirror covers and cf front lip-dieselgeek short shifter
  7. #37
    Jul 2011
    AU
    Quote Originally Posted by walbjj View Post
    Yes it is, just worked that out today. It's only taken me 9 months (including a hot QLD summer) to work that out.....
  8. #38
    Sep 2009
    seaforth, nsw
    ok, cool. i thought most euros already have this as my fathers 1999 e39 bmw 528 had it, same with his 2003 clk 320 and when my brother had his audi it had that feature, so i assumed it was a euro thing. never had it in any jap car tho
  9. #39
    Jul 2011
    AU
    do you know whether VCDS can be programmed to shut the windows with just a single press, rather than press & hold? Because really, whenever you lock the car, you're going to want the windows to go up....
  10. #40
    Sep 2009
    seaforth, nsw
    sorry, no idea, i usually hit the window up button when i take the key out as i park the car up. key doesnt need to be in the ignition, or rather u can take the key out asnd it still closes.
    also, it takes only a few seconds to hit and hold, probably gives u time to be aware of the cars surrounding as well i guess
