Page 2 of 6 FirstFirst 1234 ... LastLast
Results 11 to 20 of 51
Thread: Mk6 GTI VCDS ( VAG-COM ) codes
    hey mate, i took up round there for my first drive after picking up from the dealer!! and yeh a cruise sometime would be cool, got the apr tune done, haven't tried yet still running in, can't wait though!
    2010 MkVI GTI Carbon Steel, Leather, Sunroof, Dynaudio, MDI, Detroits, ACC and i went the manual! Stg2 APR tune.
    Jan 2007
    brisbane QLD
    Hi all,
    could someone with a car fitted with bi-xenon please post up the correct coding for the proper DRL set up?
    I'm trying to set it up properly for a mate but couldn't find it.
    Also, the option for single stage unlocking is not present in the MFD. Can this option be brought to the MFD on coding too?
    Cheers guys,
    Lams
    Main Dub:
    2010 Crafter Hanover Bus
    1956 Type 1
    2015 vRS wagon black on black
    See here
    Redman.
    MkVI GTI Reflex Silver, DSG, 18' Detroits, Xenons, Leather, Sunroof, DynAudio, MDI
    Hi mate, Go to http://forums.vwvortex.com/showthread.php?4743553
    Has some good VAGCOM coding in there
    Jan 2007
    brisbane QLD
    thanks, I did go there and got the 'staging' and rain sensor window closing working
    but the car came out of the showroom with the low beams & tail lights on all day. I read somewhere here that you guys have successfully put the correct DRLs on with the bixenon (instead of using the bi-xenon) ?
    also the car has the two stage unlocking enabled, but the option is not in the MFD to make it a one stage unlocking process. I haven't had any luck in finding it in VCDS.
    Main Dub:
    1956 Type 1
    Mar 2010
    Only got my Bi-xenons turned off as DRL at the dealer. Dunno what he did...
    MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
    Jan 2007
    brisbane QLD
    I've turned them off for him as well. Looks like the xenon headlight doesn't run a DRL bulb
    Can you select single/two stage unlocking in your MFD?
    Main Dub:
    1956 Type 1
    May 2010
    Quote Originally Posted by MkVIGTI View Post
    It's interesting that some say it can be done and some can't. My dealer spoke with VWA (probably their first mistake there) and were told it can't be done.
    I was also told the static cornering lights can't be turned on with bi-xenons either.
    GTI | Carbon | Man | 5 door | Leather | 18" Detroit | Bluetooth | MDI | Bi-Xenon
    Feb 2009
    Sydney, Australia
    Originally it couldn't... now it can. Some dealers may not be up to date.
    Nov 2009
    Quote Originally Posted by bjays76gti View Post
    I had my Mk6 GTI in for coding changes today, the tech had an issue with trying to activate the 'static turning lights' After you access the long coding helper on VCDS, which is the exact byte to change? to be able to bring up the check box to activate? Is this thats all thats required?
    I enabled the Static Cornering Lights with Fog Lights on my GTI today. Took a little while to find; I believe it's the bottom-most tickbox for byte 14 in the long coding helper.
    Interestingly, the relevant fog light comes on when I turn on my indicator as well (as long as it's below the requisite 40km/h or whatever the speed threshold is). According to the VWVortex thread this may be controlled by byte 17, but I didn't touch that, so was a little surprised when I noticed it enabled.
