Hi Everyone,
My 2011 Mk6 GTI developed a dreaded dreaded ECP fault yesterday.
I performed a VCDS Scan today which follows.
I have an idea what the issue is but would appreciate some feed back from the forum membership.
Can somebody please diagnose my problem?
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 2E 37 42 44 46 52 55 56 62 72 77
VIN: WVWZZZ1KZBW****** Mileage: 103470km-64293miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0050
Revision: AAH18--- Serial number:
Coding: 0403000C18070160
Shop #: WSC 01357 011 00200
VCID: 67F36E7E56A3D87948-8032
4 Faults Found:
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 21
Reset counter: 255
Mileage: 102177 km
Time Indication: 0
Date: 2011.07.21
Time: 17:05:50
Freeze Frame:
RPM: 838 /min
Load: 24.3 %
Speed: 0.0 km/h
Temperature: 99.0°C
Temperature: 53.0°C
Absolute Pres.: 1020.0 mbar
Voltage: 13.843 V
012425 - Signal Line for Fuel Pump Electronics
P3089 - 000 - Electrical Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 21
Reset counter: 255
Mileage: 102177 km
Time Indication: 0
Date: 2011.07.21
Time: 17:05:50
008504 - Accelerator Position Sensors (G79) / (G185)
P2138 - 000 - Implausible Correlation - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 103455 km
Time Indication: 0
Date: 2011.08.20
Time: 07:14:42
Freeze Frame:
RPM: 2839 /min
Load: 40.4 %
Speed: 76.0 km/h
Temperature: 96.0°C
Temperature: 27.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
008482 - Accelerator Position Sensor (G79)
P2122 - 000 - Signal too Low - Intermittent - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 103455 km
Time Indication: 0
Date: 2011.08.20
Time: 07:14:42
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE
Component: ESP MK60EC1 H31 0108
Revision: 00H31001
Coding: 163B600D092200FB680B06E6901D0081350800
VCID: 76CD333AC10931F1C3-8022
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 4
Reset counter: 113
Mileage: 103400 km
Time Indication: 0
Date: 2011.08.19
Time: 07:31:17
Freeze Frame:
Count: 0
Count: 32768
Count: 4608
Count: 8196
Count: 49920
Count: 0
Count: 65280
Count: 0
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 087 J HW: 1K0 937 087 J
Component: BCM PQ35 H 103 0615
Revision: 00103 AE
Coding: 4A180A3A8037F1C040080080340009E441550488736D8D60E4 8000240040
VCID: 3851FD028B9D878111-806C
Subsystem 1 - Part No: 5K2 955 119
Component: Wischer 09031 26 0512
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 060411 05 54 0403
Coding: 0330AD
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
1 Fault Found:
00061 - Footwell Lights
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 5
Fault Frequency: 254
Reset counter: 113
Mileage: 91276 km
Time Indication: 0
Date: 2016.07.14
Time: 15:37:12
Freeze Frame:
Term 15 On
Voltage: 11.10 V
ON
ON
Term 50 Off
OFF
OFF
