Ok so I've tried different things in vcds but whatever I put in it shows this text. (I've got the led bulbs on the way but wanted to try the fogs at a dimmed value)
This appears to be an uninitialised control module;
Valid wsc/importer/equipment data may be required.
Click yes for vcds to use default values of 12345/123/12345.
Click no for vcds to try the values currently in the module.
Click cancel to go back and manually edit the values.
What do I do? I don't want to do something that I shouldn't
Cheers.
