Results 1 to 10 of 14
Thread: Mk5 fog lights as drl?
    Aug 2009
    Is it possible to have the fogs as drl's?
    I know its sometime's frowned upon but I've seen a few gti's running them.
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Pacific Paradise QLD
    Quote Originally Posted by audi-tone View Post
    Using fogs is illegal unless weather is inclement Not that anyone takes any notice.
    I believe there is a way around that law by using LED Bulbs in the Fog Lights. I've seen a GTD driving around with LED Fog Lights for most of this year and he said he's been pulled over many a time and never even talked to about his fog lights.
    To answer the OP, yes you can VAGCOM it so that the Fog Lights are always on while the car is running. There's a setting for them to act a DRL, but it escapes me right now. I hate people using their Fogs (Halogen) during the day as it's just too bright and looks like ****e. Get some LED bulbs if you're really considering it. To make them easy on the eyes, but to also make you stand out/be identifiable.
    Aug 2009
    Ill look into led bulbs then.
    I'm guessing you'd need new les lights hey? Unless the bulbs are changeable to led?
    Cheers.
    Nov 2010
    Burpengary, Queensland
    Cheers.
    You can buy HB4 LED globes and code the fogs to act as DRLs. So you would not be able to switch them off in the usual way. You can also adjust the brightness via VCDS.
    Aug 2009
    Great. Now to find some bulbs and how to code them in.
    Nov 2010
    When you get the bulbs, I've got a cable you can use.
    Aug 2009
    I've gotta cable at the moment. Just the coding I need!
    Thanks for offer though.
    May 2013
    Orange NSW
    The fogs can be set as DRLs using VCDS and the intensity can be dimmed so they are not full brightness. I set mine to 50% although I am considering taking them to 40% to see if they are still OK. I think the module you need to code is the CECM. There is a reasonable difference and it is obvious they are not operating as fogs when dimmed. They work until the normal lights switch on when the daylight gets too dim, then the headlights switch on and turn off the "DRLs" at the same time.
    08 MY09 R32, DBP, DSG, GIAC, R8V10 reps, KW V3, RNS510/VIM/BT/MDI, region free DVD, switched Haldex, s2t paddles,HPA dogbone rubber,Mk7 climatronics, FIS+, Adams/RDA discs & Hawk pads, Garage button, GruppeM. Front fogs, Milltek. CF Chin spoiler.Strut support. LEDs Alloy front suspension bits.....
    http://photobucket.com/gregsr32
    QLD
    This is true, HOWEVER if the DRL function is operating at a dimmed level they are no longer fog lights, they are DRLs. set mine at 30%
    Octavia vRS TDi DSG MY10 - RD Technik tuned
    Polo 9N3 1.9TDi
