@Sharkie: Hi.
Hmm...... as for the RVC not working - I assume that this mk7 has a bog-standard low-line version camera installed, meaning that the car does NOT have the version RVC that has its own module (connected @ address hex6C on the CAN network).
If so, it could be (I'm guessing, of course) that the donor car might have had the high-line version RVC installed. If so, the software switch in the long-code string that tells the MIB to operate a RVC will be deactivated (because the camera is controlled by the separate hex6C module for the high-line RVC).
So, I suggest that you check Byte 19, Bit 4 - see below:
For the "car image" - this is a tad more tricky because the MIB's understanding of what type car it is installed-in and how to display the image depends on the settings in a few Bytes. So, rather than me guessing - it's probably better if you post-up the long-code strings for both the old and new MIB units (look at an old SCAN for the long-code on the original MIB).
