You need to add telephone (address 77) to the list of installed modules in the canbus gateway (address 19).
Hello.
I have recently installed a RCD-510 and 9W7 bluethooth kit in a 2008 MKV Gti with an existing PF03 and stock can-gateway.
Everything is working as expected on the Radio side of things, including bluetooth, microphone etc..
However, I can not access the MFD bluetooth menu.
I figured this was something to do with VCDS coding. I have a vagcom cable and currently there are no faults.
Any advice would be very much appreciated.
Cheers,
James
Might be helpful to post the autoscan
Saturday,02,September,2017,15:03:57:33552
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
Ross-Tech: Home
VIN: WVWZZZ1KZ8U005320 License Plate:
Mileage: 257020km-159704mi Repair Order:
Chassis Type: 1K-VW35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 75 77
VIN: WVWZZZ1KZ8U005320 Mileage: 257020km-159704miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0G63N58GO
Coding: 040300431C070160
Shop #: WSC 14645 025 402983
VCID: 346D270B57B87FE65E-8060
No fault code found.
Readiness: 0000 0001
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 044 J HW: 02E 927 770 AE
Component: GSG DSG 081 1407
Revision: 00008010 Serial number: 00000706181518
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 1C3DEFABDF28D7A676-8048
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 00046 412 00000
VCID: 73EFE417123638DE87-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BR HW: 1K0 907 044 BR
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 78F5D33B0B505B86B2-802C
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007164270
Coding: E58D0D2700041500471400001400000000087F075C00010000 0000000000
VCID: 71E3EE1F682A0ACE75-8024
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 220807 020 0501
Coding: 00049109
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
Component: RLS 040707 046 0204
Coding: 00208933
Shop #: WSC 00046
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD19P4KM
Coding: 0012624
VCID: 3D7B022F64F2BEAEA1-8068
Subsystem 1 - Serial number: 6332MSME16206600Z
Subsystem 2 - Serial number: 6342MSME19491077A
Subsystem 3 - Serial number: 6352QSME2D2C2E67Z
Subsystem 4 - Serial number: 6362QSME2E0E3F21T
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012122
VCID: 0103BEDF588A1A4E85-8054
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 874 HW: 1K6 920 874
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G63N58GO
Coding: 0003103
Shop #: WSC 20048 959 69581
VCID: 70E5EB1B632003C67A-8024
Address 19: CAN Gateway Labels:. 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 300507F1000542
Coding: ED807F063006020003
Shop #: WSC 00046 412 12345
VCID: 30652B1BA3A043C63A-8064
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120B
Coding: 0000692
VCID: 3875133B4BD09B8672-806C
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 36691D0341C46DF660-8062
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 030FB4D74296085E97-8056
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Subsystem 3 - Part No: 1K0 951 178 A
Component: Innenraumueberw.003 0203
Address 47: Sound System Labels: 3C0-035-456.clb
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000139292
VCID: 2A513973857C3916F4-807E
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Coding: 0000692
VCID: 3973163F70DA828E8D-806C
Address 56: Radio (J0503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 5K0 035 190 A HW: 5K0 035 190 A
Component: Radio RCD510 050 0207
Revision: 00000001 Serial number: VWZ1Z3L1586948
Coding: 01000000010005
Shop #: WSC 01357 011 00200
VCID: 234FD4572256E85EB7-8076
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 00046 412 1012544
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 K HW: 1K0 959 704 K
Coding: 0000144
Address 75: Telematics
Cannot be reached
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 7P6 035 730 P HW: 7P6 035 730 P
Component: TELEFON H15 4217
Revision: 1B001001 Serial number: 00007665756135
Coding: 0A00000000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3F877827A6FEACBEB3-806A
End-------------------------(Elapsed Time: 02:03)--------------------------
Looks OK, might be something that needs to be tweaked in the Polar FIS settings?
I'm not familiar with the ins and outs of the PS03 as I've never owned one so can't offer much guidance there sorry.
It's the polar fis that does the translation from BAP to DDP so if it's not working correctly your instrument cluster won't know what to do with commands from the BT module.
