Results 1 to 10 of 13
Thread: Helpful info fo the MkV
    Sep 2008
    Melbourne, Australia
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
    Nov 2007
    Perth
    More Links -
    Ross Tech manufacture the cable & VCDS Software:
    Purchasing link:
    http://www.ross-tech.com/Merchant2/m...ry_Code=VAGCOM
    FAQ
    http://www.ross-tech.com/vag-com/vag-com-faq.html
    WIKI (has an extensive list of Fault Codes)
    http://wiki.ross-tech.com/index.php/Main_Page
    Online demo/manual
    http://www.ross-tech.com/vcds/tour/main_screen.html
    Chances are... you could have found these links yourself if you know how to use a website, but here they are anyway
    Jan 2008
    Sunshine Coast
    Sweeeet! Can anyone that has a vag-com trick please post it here, regardless of how "simple" it may appear. I'd love this to become a sticky for everyone, especially newbies like me ( in the area of Vag-com! )
    Sep 2008
    Alarm Beep
    Alarm beeps for lock and unlock
    Bazzle
    Attached Thumbnails Attached Thumbnails Helpful info fo the MkV-30102008501s-jpg   Helpful info fo the MkV-30102008502s-jpg
    Sep 2008
    Rain closing
    Rain closing of windows and roof enabled. Couldnt post here as pix too big. Use linky
    http://forums.eurocca.net/showthread.php?t=30804
    Bazzle
    Sep 2008
    Speedo error reduced
    Changed stting in instruments to read more pulses so speedo reads less by about 3%.
    Means 100kph now at 103 instead of indicated 107.
    Moved speedo needle anticlockwise one click and it now reads spot on.
    Cant find my VCDS pix (Maverick has some I believe)
    Bazzle
    Jan 2009
    canberra
    got my vag-com cable etc yesterday - when i get it loaded up onto my laptop i'll see if i can see where i can enable the paddle shifting for my new steering wheel on thursday ... hopefully should be good to go
    Apr 2008
    blackwood sa
    Quote Originally Posted by CL455 View Post
    Its in the steering wheel controller. Long coding. check the box and click do it.
    Jan 2009
    Brisbane, QLD.
    Did you get one from Ross-tech? or someone else?
    Got a link? : D
    Sep 2008
    Quote Originally Posted by chewy7 View Post
    Got a link? : D
    Got mine by phone from Harding performance
    o/n to Melb.
    http://www.ross-tech.com/distributors.html
    Bazzle
