Please report back to the forum with your outcome. It helps anyone else who may have a similar issue in the future![]()
It ended up being the connection plug wasnt quite connected.
The fans now work but still both coming on high speed for about 5 minutes after engine is turned off.
I replaced the coolant temp. sensor next to the battery but that didnt fix it.
No fault codes.
Does any one know where all the temp. sensors are?
The fans will run to cool the engine and particularly the turbo.
Is the engine temp now normal when driving?
Sound like you've already fixed the problem?
Yes temps are normal but the fans go flat out at high speeds for about 5 minutes after i turn the engine off every time i drive unless it doesnt get up to running temp.
Any new fault codes?
^^^ hm................. sounds perfectly reasonable behavior for a car that's driven in Queensland this time of year - especially if it's driven in the CBD (stop start traffic) - I think
