Results 1 to 10 of 20
Thread: Help with coding please
    Hi everyone,
    My Audi S3 8p has a problem where i was driving home and the temp needle started to rise on a very hot day and traffic, so pulled over and looking for a shaded park the temp went down to normal straight away, so i drove home carefully dodging traffic.
    In the garage i left the engine on and noticed no fans running and tried the air con on and still both fans not running. Took awhile for the temp to rise again.
    Air con is working but receiving warm air. Slightly cool at first.
    I got it scanned with a OBDeleven and these are the fault codes.
    Can someone please explain them and what do i need to do and what parts etc, with out using a Audi dealer. Thanks
    This was the codes on Tuesday
    Trouble codes:
    P0480 - Cooling Fan 1 Control Circuit Implausible signal
    static
    Measurements:
    0 U/min
    0 %
    0 km/h
    96 °C
    67 °C
    1000 mbar
    12.319 V
    -0.0 °v.OT
    Date: 2016-11-08 16:06:59
    Frequency counter: 67
    Mileage: 132265 km
    Driving cycle: 255
    Priority: 0
    P0691 - Cooling Fan 1 Control Circuit Low Lower limit not reached
    Intermittent
    Measurements:
    2105 U/min
    26 %
    70 km/h
    78 °C
    24 °C
    1010 mbar
    14.224 V
    -1.1 °v.OT
    Date: 2016-11-10 07:16:16
    Frequency counter: 15
    Mileage: 132302 km
    Driving cycle: 255
    Priority: 0
    01 Engine Control Module 1
    08 Air Conditioning
    System description: KlimavollautomatH19
    Software version: 0420
    Hardware number: 8P0820043AG
    Trouble codes:
    00796 - Blower for temp. sensor Open circuit
    Intermittent
    Measurements:
    13.6 V
    37.5 °C
    System description: 2.0l R4/4V TFSI
    Software version: 0010
    Hardware number: 8P0907115S
    Serial number: AUX7Z0GNFNG0PU
    Long coding: 01030003180F0160
    These was the codes Saturday
    Trouble codes:
    Intermittent
    Measurements:
    778 U/min
    15 %
    0 km/h
    107 °C
    Date: 2016-11-29 18:26:25
    Mileage: 132759 km
    Driving cycle: 255
    Priority: 0
    08 Air Conditioning
    Serial number: 8P0820043AG
    Trouble codes:
    Intermittent
    Measurements:
    13.9 V
    25.0 °C
    Date: 2016-12-01 07:11:41
    Frequency counter: 2
    Mileage: 132787 km
    Driving cycle: 223
    Priority: 3
    First thing to check would be the engine fan's fuse.
    Check your manual for the location, its probably a fairly big fuse like 50amp or something.
    If its the connection to the fans that faulty, can you use wire connectors and heat shrink. Would that cause an issue with scanning?
    The errors are telling you that there is a problem with a fan (blower) it is not a 'scanning issue'.
    Check the fan fuse first (in the fusebox). It may be blown.
    If you aren't confident checking this then go to a mechanic or auto electrician.
    Cant find the fan fuses/relay.
    Check the manual?
    It's either in the fusebox next to the driver in end of dash panel or under the bonnet.
    More likely the latter I would think for engine fan fuse.
    forums.vwvortex.com/showthread.php?3126433-For-those-with-A-C-and-or-Fan-issues-(Engine-Bay-Fuse-identification-too)
    Dec 2006
    Kilsyth, VIC
    While checking the fuse I would also be checking that the fan is plugged in... Unplug it, blow out the connector and plug it back in for good measure.
    Check the manual?
    Is this the same location as the link you posted or is it some where else? Some one else had the same problem and replaced the 50 amp fuse on the 3rd cable.
    Attached Thumbnails Attached Thumbnails Help with coding please-contactphoto-img_20161204_112632-jpg
    Do you have a bad fuse? If so replace it.
    Dec 2006
    Kilsyth, VIC
    Do you have a multimeter or a test light to test across the fuse?
