Reedy: Wow - that's an impressive list of trouble-codes on the CAN gateway!
My suggestion (for what it's worth) is that you try to clear all the DTCs, then re-poll the module. If any trouble codes reappear, post-up your history report.
Use the [code] tag at the start of the cut-and-paste and the [ /code] tag at the end if your history report is long.
If you do this correctly, you should get something that looks like this:
Code:
This is a copy of Reedy's history report from his/her OBD11 dongle
Use the Reply with Quote option to see how the tags work
