Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Golf R Fault Codes - CAN Gateway
    Jan 2012
    Hey folks, not wanting to sound like too much of an amateur but I have these Fault codes in the Gateway section on the obd11. Unsure whether they were there before I started tweaking but just happened to come across them. The car has no engine on and runs perfect.
    Tweaks performed
    3 to 4 blinks
    Auto coming home lights with drivers door
    Lock unlock chirp
    Sunroof open fully on unlock
    Few based traffic. (Does not work)
    Auto close with rain. (Does not work)
    Help would be appreciated or just I've nothing to worry about or stop messing you amateur.
    OBDeleven data log
    Date: 2016-10-27 19:52
    VIN: WVWZZZAUZFW075389
    Car: Volkswagen Golf
    Year: 2015
    Engine: CJXB
    Mileage: 36815 KM
    19 Gateway
    System description: GW MQB High
    Software number: 5Q0907530T
    Software version: 1188
    Hardware number: 5Q0907530F
    Hardware version: 128
    Serial number: 0002316346
    ODX name: EV_GatewLear
    ODX version: 011016
    Long coding: 030100042B085900EF00027E880F0001000105000000000000 0000000000
    Subsystems:
    System description: J367-BDMHella
    Software version: 8043
    Hardware version: H03
    Serial number: 3025284003
    System description: E221__MFL-DC1
    Software version: 0038
    Hardware version: H10
    Serial number: 29140001488650084304
    Long coding: 2CFFFF
    Trouble codes:
    U106600 - Radio No Communication
    static
    Terminal 15: On
    Supply voltage, terminal 30: 11.7 V
    Unknown ambient data:
    Date: 2016-10-27 19:46:44
    Malfunction frequency counter: 1
    Unlearning counter: 202
    Mileage: 36815 km
    Priority: 2
    U104000 - Axle differential lock control module No communication
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    U114600 - Control module for special function 2 No communication
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    U100F00 - Special purpose vehicle control module No communication
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    U112600 - Undefined control module No communication
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    U104C00 - Rearview camera system control module No communication
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    U106A00 - Digital sound system control module No Communication
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    U103D00 - Trip recorder control module No communication
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    Tab2A7-20F
    2015 Golf R. Lapiz Blue.
    Reedy: Wow - that's an impressive list of trouble-codes on the CAN gateway!
    My suggestion (for what it's worth) is that you try to clear all the DTCs, then re-poll the module. If any trouble codes reappear, post-up your history report.
    Use the [code] tag at the start of the cut-and-paste and the [ /code] tag at the end if your history report is long.
    If you do this correctly, you should get something that looks like this:
    Code:
    This is a copy of Reedy's history report from his/her OBD11 dongle
    Use the Reply with Quote option to see how the tags work
    Jan 2012
    Each time I clear them they come back within seconds, for example I can almost clear them all using the bin button all the way down to about 2 left and then the module refreshes and they all come back. Funny thing is I've no engine light and the car runs fine. Would this be a trip to the main stealer?
    Jan 2012
    Kicking myself I didn't scan the car first before I started tweaking!!! Then I would know if my tweaking has caused these faults.
    Dec 2008
    Sydney/Canberra
    Incorrect coding in the Gateway, by the looks of things.
    To me, it seems to be looking for control modules that aren't installed.
    Umai Naa!! I agree that there appears to be something odd! That's why I want to see the history report. My suspicion is that there has been either a code-string error, or perhaps the gateway list has a few extra modules that shouldn't be there (perhaps)
    Jan 2012
    First of all thanks for being patient with me, I'm very much a novice which is dangerous because I like to tweak and tinker.
    Looking at faults more closely I do recognize them, they seem to be from when I tried to open the modules but the obd11 wouldn't let me, as though that funtion is not enabled on the obd11 and the the car is still trying to talk to those modules that I tried to open and don't exist. I did a hard reset on this module but they never went away. I've managed to clear them all but as soon as I refresh they all come back. Each fault though is from a module that failed to work on the obd11.
    Sent from my Tab2A7-20F using Tapatalk
    Jan 2012
    Wonder if there is a way to reset the obd11 and start again?
    Jan 2013
    Brisbane, QLD.
    Quote Originally Posted by Reedy View Post
    Tweaks performed
    3 to 4 blinks
    Lock unlock chirp
    OBDeleven data log
    Year: 2015
    Engine: CJXB
    Mileage: 36815 KM
    19 Gateway
    ODX version: 011016
    Subsystems:
    Long coding: 2CFFFF
    Trouble codes:
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    static
    Terminal 15: On
    Mileage: 36815 km
    Priority: 2
    Tab2A7-20F
    Defiantly incorrect coding in gateway. If dealer is nice enough they will recode the gateway online for you (you will loose all your tweaks), but you will still call them a stealership...
    Otherwise find a comparable Golf R and re-code your gateway yourself, next time save a autoscan/log before you tweak things. Goodluck.
    Jan 2012
    Cheers mate, I'm going to use VW for my next service so might see how I go. Are these faults effecting my car and the way it drives?
