Results 1 to 8 of 8
Thread: Golf R - Auto Scan - Fault Codes
    Mar 2009
    Sydney, Eastern Suburbs
    Hi all,
    I recently purchased a Ross Tech cable and ran an auto scan on my new R.
    Although technically savvy, I am a VAG-COM noob and would really appreciate some help in relation to my error codes!
    Things to note (not sure if they are all relevant):
    1) 2011 3 Door Golf R (Build Feb 2011)
    2) Dynaudio
    3) OEM RCD-510 just upgraded to RNS-510. Thought I had coded appropriately but am getting error codes, and the sat nav instructions are not showing on the MFD
    4) I have installed a Parrott MKi9200 with UNIKA for steering wheel controls (not sure if this is throwing the CAN BUS codes)
    I have recorded all the original coding for the changes I have made when re-coding for the RNS-510.
    Here is my auto scan. Please let me know if any more or less is needed, or if there's any VAG-COM help ettiquette I need to address.
    Hope someone can help!
    Auto Scan (only ones with faults shown):
    Mar 2009
    Sunday,24,July,2011,20:29:00:30032
    VCDS Version: Release 10.6.4
    Data version: 20110418
    Chassis Type: 7N0
    Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 37 42 44 46 47 52 55
    56
    VIN: WVWZZZ1KZBW240672
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010 [I didn't change the coding for this so not sure why there is an error]
    09-Cent. Elect. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    14-Susp. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010 [I didn't change the coding for this so not sure why there is an error]
    19-CAN Gateway -- Status: Malfunction 0010 [I didn't change the coding for this so not sure why there is an error]
    22-AWD -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011 [Thought I had coded it correctly]
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: Malfunction 1010 [Changed due to RNS-510 Coding]
    Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
    Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
    Component: Climatronic H17 1010
    Revision: 00003001
    Coding: 0000001002
    Shop #: WSC 01357 011 00200
    ASAM Dataset: EV_Climatronic A01010
    ROD: EV_Climatronic_VW36.rod
    VCID: 8021D775AA93
    1 Fault Found:
    13701376 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 157
    Mileage: 6021 km
    Date: 2004.14.16
    Time: 20:32:33
    Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
    Part No SW: 5K6 920 871 B HW: 5K6 920 871 B
    Component: KOMBI H20 0420
    Serial number: 00000000000000
    Coding: 170F01
    ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
    ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
    VCID: 334BC8B92BA5
    2 Faults Found:
    12648448 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 2
    Reset counter: 157
    Mileage: 6021 km
    Date: 2004.14.16
    Time: 20:32:32
    13639168 - Function Restricted due to Missing Message(s)
    U1111 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 133
    Mileage: 5114 km
    Date: 2004.14.05
    Time: 09:46:30
    Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
    Part No SW: 7N0 907 530 C HW: 1K0 907 951
    Component: J533 Gateway H37 0614
    Revision: H37 Serial number: 190211F1002617
    Coding: 350001
    VCID: 3041C7B5DAB3
    2 Faults Found:
    01304 - Radio
    004 - No Signal/Communication - Intermittent
    Freeze Frame:
    Fault Status: 00110100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 6648 km
    Time Indication: 0
    Date: 2004.14.22
    Time: 18:27:13
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 1
    Fault Frequency: 8
    Mileage: 6648 km
    Time Indication: 0
    Date: 2004.14.22
    Time: 19:03:31
    Mar 2009
    Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
    Part No SW: 1T0 035 680 D HW: 1T0 035 680 C
    Component: RNS-MID H42 3890
    Revision: AB001001 Serial number: VWZ6Z7Z5602354
    Coding: 04050002010000A00000
    Shop #: WSC 05314 000 00000
    ASAM Dataset: ------------------------- ------
    VCID: 2F43C4C9C78D
    15 Faults Found:
    00871 - Bass Speaker Front Right (R23)
    011 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00101011
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 168
    Mileage: 5144 km
    Time Indication: 0
    00870 - Bass Speaker Front Left (R21)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 168
    Mileage: 5144 km
    Time Indication: 0
    00873 - Bass Speaker Rear Right (R17)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 168
    Mileage: 5144 km
    Time Indication: 0
    00872 - Bass Speaker Rear Left (R15)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 9
    Reset counter: 168
    Mileage: 5144 km
    Time Indication: 0
    00856 - Radio Antenna
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 137
    Mileage: 5144 km
    Time Indication: 0
    00821 - Antenna 2 for Radio (R93)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 4
    Reset counter: 137
    Mileage: 5144 km
    Time Indication: 0
    00874 - Treble Speaker Front Left (R20)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 6648 km
    Time Indication: 0
    00876 - Treble Speaker Rear Left (R14)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 6648 km
    Time Indication: 0
    00875 - Treble Speaker Front Right (R22)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 6648 km
    Time Indication: 0
    00877 - Treble Speaker Rear Right (R16)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 168
    Mileage: 6648 km
    Time Indication: 0
    03138 - Input AUX IN
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 128
    Mileage: 6648 km
    Time Indication: 0
    Date: 2004.14.22
    Time: 19:20:57
    01523 - Microphone for Telephone (R3
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 19
    Reset counter: 128
    Mileage: 0 km
    Time Indication: 0
    01305 - Databus for Infotainment
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    00862 - Antenna for GPS Navigation (R50/R52)
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 13
    Reset counter: 168
    Mileage: 0 km
    Time Indication: 0
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 5
    Fault Frequency: 1
    Mileage: 0 km
    Time Indication: 0
    End
    Mar 2009
    Apologies for the length - not sure if there's an easier way to post about VAG-COM.
    I should note that before I installed the RNS-510, but AFTER the Parrott install, the scan was slightly different.
    Unfortunately I haven't got a scan of before the Parrott was installed as I only bought the cable recently.
    Scan from before RNS-510 and associated re-coding:
    08-Auto HVAC -- Status: OK 0000
    47-Sound System -- Status: Malfunction 0010
    55-Xenon Range -- Status: Sporadic communication error 1000
    Delete the codes and scan it again. Lots of those open circuit ones will be due to disconnecting the radio with the battery connected.
    brisbane
    you need to recode your gateway to say its now got a sat nav unit and recode the sat nav to say its got dyn audio ect then hard reset the sat nav unit by pressing the 4 buttons across the top eject info/star button ect that should bring display on mfd should be able to find a thread on here or have a look on mygti.com for further instructions delete all faults and see whats left
    Jul 2011
    Looks like your you have coding issues!!! Use the long coding helper when you select the navigation unit(56) choose which systems you
    have installed in the car then reset unit as mentioned by bushnut.... if you keep getting faults for wrong coding try again....
    Mar 2009
    Quote Originally Posted by bushnut View Post
    Thanks for the advice guys - very helpful as I felt a bit lost in the world of VAG-COM!
    - I had coded the Sat Nav for Dynaudio - I get the symbol when the unit starts up. It could be that I coded it to Dynaudio BAP DSP, rather than just Dynaudio. Might try that. I have also reset the unit after coding. The RNS-510 seems to be behaving ok.
    - I don't think I coded the CAN Gateway to tell it I have Satnav - that explains the lack of sat nav in the MFD.
    - Other issues are HVAC & Instruments: I wasn't sure about deleting the fault codes - thought it might be a bad idea, but sounds like it's the way to go.
    Will give that a go.
    Cheers!
