Results 11 to 20 of 22
Thread: Golf GTI MK6 - Bluetooth 9W7 Coding
    Dec 2009
    Interested thread!
    I just fitted a 9W7 unit to my '09 R36 Passat, everything is working and can view all necessary data on the RNS, and the white MFD shows my iphone status BUT, I can't actually scroll into my contacts/call register on the MFD via the steering wheel buttons?
    It is strange because if the phone rings, the MFD displays that there is a call coming in, and whether I want to answer or not, but when I try and answer via the steering wheel the buttons aren't recognised.
    Everything else can be accessed via the MFD, vehicle data, convenience, nav etc.
    Is there something steering wheel related I haven't enabled in VCDS?
    Dino.
    SQ5 V6TDI | 911TT | Polo 6C
    Aug 2011
    vic
    Take a look at the last byte under Telephone channel, but also look at the Steering Wheel channel and select adaptation. The hints should help you select the right button combo.
    Dec 2009
    It is the standard steering wheel on there atm, although I will be fitting a Golf R wheel in a month or so.
    From what you've said, it would appear that my steering wheel isn't set up correctly to access the phone data being displayed on the MFD?
    Like I said, it all displays perfectly, when I miss a call it displays that on the MFD, but I can't manipulate the 'view missed call' [yes] or [no] etc.
    Dino.
    Aug 2011
    vic
    Quote Originally Posted by PASHN8 View Post
    If you have the cable and software, look at those sections i mentioned, also if you are there on tuesday i can take a look when i come to pick up the lip.
    I dont exactly know the answer, i am new to this too :O
    Dec 2009
    No problem, i'll take a look. I have the latest VCDS and HEX-CAN-USB Ross-Tech cable also.
    Dino.
    Dec 2009
    Ok, my 9W7 will not allow me to change the 'Soft Coding' and in the '77 - Telephone' simply says 'Long Coding'.
    My default '77- Recode Module' inside is '0200000000010110', does this look like the standard 9W7 Bluetooth long code?
    The model I have is the '7P6 035 730 D' H05 0440
    Dino.
    Aug 2011
    vic
    the standard setting i believe is:
    0A01000000010110
    as bluewagen told me to make it this to debug some issues. :O
    Dec 2009
    Doesn't make sense as the code has too many digits and cannot be entered as a result?
    Dino.
    Dec 2009
    Actually on second look, it looks similar to my character length?
    Anyone confirm or deny a similar experience?
    Dino.
    Jul 2010
    have a look at this pdf - the last 7 or so pages talk about coding the steering wheel.
    might b of assistance for u.
    MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
