Take a look at the last byte under Telephone channel, but also look at the Steering Wheel channel and select adaptation. The hints should help you select the right button combo.
Interested thread!
I just fitted a 9W7 unit to my '09 R36 Passat, everything is working and can view all necessary data on the RNS, and the white MFD shows my iphone status BUT, I can't actually scroll into my contacts/call register on the MFD via the steering wheel buttons?
It is strange because if the phone rings, the MFD displays that there is a call coming in, and whether I want to answer or not, but when I try and answer via the steering wheel the buttons aren't recognised.
Everything else can be accessed via the MFD, vehicle data, convenience, nav etc.
Is there something steering wheel related I haven't enabled in VCDS?
Dino.
SQ5 V6TDI | 911TT | Polo 6C
It is the standard steering wheel on there atm, although I will be fitting a Golf R wheel in a month or so.
From what you've said, it would appear that my steering wheel isn't set up correctly to access the phone data being displayed on the MFD?
Like I said, it all displays perfectly, when I miss a call it displays that on the MFD, but I can't manipulate the 'view missed call' [yes] or [no] etc.
Dino.
No problem, i'll take a look. I have the latest VCDS and HEX-CAN-USB Ross-Tech cable also.
Dino.
Ok, my 9W7 will not allow me to change the 'Soft Coding' and in the '77 - Telephone' simply says 'Long Coding'.
My default '77- Recode Module' inside is '0200000000010110', does this look like the standard 9W7 Bluetooth long code?
The model I have is the '7P6 035 730 D' H05 0440
Dino.
Doesn't make sense as the code has too many digits and cannot be entered as a result?
Dino.
Actually on second look, it looks similar to my character length?
Anyone confirm or deny a similar experience?
Dino.
have a look at this pdf - the last 7 or so pages talk about coding the steering wheel.
might b of assistance for u.
MY17 Superb 162TSI, Business Grey, Tech+Comfort Pack, APR ECU+TCU Stg 1, SLA, Rieger Splitter + Side Skirts, Eibach Pro-Kit Springs, Hardrace Swaybar, TPMS
