Are You sure, the E1 switch pin 2 is connected to the BCM A20 ?
Hi All
I am having some issues with the headlights, namely:
1) The Xenon Headlights when set to Auto in the car - do not turn off even in bright daylight. They will stay on ALL the time no matter what. I have tested the sensor in Output Tests and it changes from 0-7 when driving into sun (7 being in direct sun) and it still says lights should be on.
3) Lights turn off as soon as the ignition is off - no coming/leaving home lights (car switch in auto) and also do not turn on when car unlocked.
I have plugged in my VCDS cable, and taken a scan, posted below. I have turned on coming and leaving home lights in the MDI and they appear selected in VCDS.
There does appear to be an error with the light switch in the DTCs
Your advice is much appreciated:
Code:01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: OK 0000 Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb Part No SW: 5K0 907 044 BS HW: 5K0 907 044 BS Component: Climatronic H15 0709 Revision: 00003001 Coding: 0000001002 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_SE36.rod VCID: 7DDF2C51EC864AC904D-8028 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 087 J HW: 1K0 937 087 J Component: BCM PQ35 H 103 0615 Revision: 00103 AD Coding: 46180A388825F1C040080080250008C445650088736D8960E48000040040 Shop #: WSC 01357 011 00200 VCID: 3851FD458B24AFE197B-806D Subsystem 1 - Part No: 1K2 955 119 F Labels: 1KX-955-119.CLB Component: Wischer 08101 26 0512 Coding: 009795 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 231010 05 54 0403 Coding: 012BAD Subsystem 3 - Part No: 1K8 951 171 Component: DWA-Sensor 00 001 0104 Subsystem 4 - Part No: 1K8 951 605 A Component: LIN BACKUP HO H11 9004 1 Fault Found: 01800 - Light Switch (E1) 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 3 Fault Frequency: 8 Reset counter: 137 Mileage: 45313 km Time Indication: 0 Date: 2014.11.02 Time: 18:25:33 Freeze Frame: Term 15 On Voltage: 13.65 V ON ON Term 50 Off OFF OFF ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb Part No SW: 5K0 919 475 D HW: 5K0 919 475 Component: PARKHILFE 8K H07 0010 Revision: -------- Serial number: 48341022200738 Coding: 100104 Shop #: WSC 01357 011 00200 VCID: 3753FE79863AA0999E1-8062 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels: 5K0-959-655.clb Part No SW: 5K0 959 655 D HW: 5K0 959 655 D Component: AirbagVW10 037 0606 Serial number: 003FKRAEJMVW Coding: 00003131 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_AirbaVW10SMEVW360 A01011 ROD: EV_AirbaVW10SMEVW360_SK35.rod VCID: 3B5BE249B21284F97A9-806E Crash sensor for side airbag; driver side: Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Fahr.V H01 ---- Serial number: 3572MSME14554159ZZZR Crash sensor for side airbag; front passenger side: Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354 Component: S.Sens.Beif.V H01 ---- Serial number: 3582MSME374C2155ZZZX Crash sensor for side airbag; rear; driver side: Component: S.Sens.Fahr.H --- ---- Serial number: 3512QSME3E136B4AZZZ0 Crash sensor for side airbag; rear; passenger side: Component: S.Sens.Beif.H --- ---- Serial number: 3522QSME263A6B7BZZZ5 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B Component: Lenks.Modul 007 0080 Revision: -------- Serial number: 90440JJI001OL Coding: 1892140000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_SMLSNGKUDS A05001 ROD: EV_SMLSNGKUDS_SE36.rod VCID: 76CD337DC9B01991457-8023 Multi Function Steering Wheel Control Module: Subsystem 1 - Part No SW: 5K0 959 542 HW: 5K0 959 542 Labels: 3C8-959-537.CLB Component: E221__MFL-TAS H06 0010 Serial number: 0161954 Coding: 830000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb Part No SW: 5K6 920 871 B HW: 5K6 920 871 B Component: KOMBI H20 0420 Serial number: 00000000000000 Coding: 170F01 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089 ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod VCID: 334BCA699A424CB9A29-8066 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb Part No SW: 7N0 907 530 HW: 1K0 907 951 Component: J533 Gateway H27 5603 Revision: H27 Serial number: 251010F2003377 Coding: EDA37F0600060200000003 Shop #: WSC 01357 011 00200 VCID: 6DFF1C1174E6DA49B4D-8038 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD Labels: Redir Fail! Part No SW: 0BR 907 554 B HW: 0BR 907 554 B Component: Haldex 4Motion 3017 Coding: 0000005 Shop #: WSC 00000 000 00000 VCID: 44A999B507ECFB010B3-8011 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H20 0420 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008 ROD: EV_Immo_UDS_VDD_RM09_SE25.rod VCID: 6AF5170D8D08CD71D1F-803F No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 5K0 959 701 B HW: 5K0 959 701 B Component: Tuer-SG 009 2120 Coding: 0000692 Shop #: WSC 01357 011 00200 VCID: 3147C061A85E7EA9D05-8064 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K0 909 144 J Component: EPS_ZFLS Kl. 74 3001 Revision: 00H17000 Shop #: WSC 01357 011 00200 VCID: 3147C061A85E7EA9D05-8064 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl Part No SW: 5K0 959 702 E HW: 5K0 959 702 E Component: Tuer-SG 009 2152 Coding: 0000948 Shop #: WSC 01357 011 00200 VCID: 354FF4715C3652898CD-8060 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0148 Revision: 00H04000 Serial number: Coding: 1475932 Shop #: WSC 01357 011 00200 VCID: 3449C975574C4B81BB3-8061 Subsystem 1 - Part No: 7L6 941 329 B Component: AFS-Lst.-Modul l 0004 Coding: 00000022 Subsystem 2 - Part No: 7L6 941 329 B Component: AFS-Lst.-Modul r 0004 Coding: 00000022 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0503) Labels: 5M0-035-1xx-56.clb Part No SW: 5K0 035 190 HW: 5K0 035 190 Component: Radio RCD510 041 0167 Revision: 00000001 Serial number: VWZ1Z3K3572072 Coding: 0500000001 Shop #: WSC 01357 011 00200 VCID: 62E57F2D7D38953119F-8037 No fault code found.
MkV (2007) Golf R32 | Black | Fully Standard - For now!
Just to let everyone know this is fixedwas just a coding mistake!! Thanks to some help from good people on the forums, sorted it out
