Look for splits in the intake pipe, breather hoses and vacuum hoses.
The O2 sensor(s) are picking up a lean mixture after the air mass sensor.
G'day,
Hooked up VCDS to my daughter's 2003 model 2.0 litre Golf 4 to see why it was consuming around 20 litres/ 100km. Got the following engine codes. I guess the engine ECU is over-compensating for the lean fuel mixture, hence the high fuel consumption. If I disconnect the battery for more than 15 mins, the fuel consumption improves to around 8.5 litres/100km (but then gradually deteriorates until the next battery reset).
What do you think is the cause? Is there a code preset that can be done to fix the fuel mixture fault? Thanks..
Address 01: Engine Labels: 06A-906-018-AQY.lbl
Part No: 06A 906 018 GP
Component: 2.0l R4/2V MOTR AT V01
Coding: 00033
Shop #: WSC 01271
VCID: 76E3F91F52E30AAEB1B-4AE8
2 Faults Found:
16555 - Fuel Trim; Bank 1
P0171 - 35-10 - System Too Lean - Intermittent
17536 - Fuel Trim; Bank 1 (Mult)
P1128 - 35-10 - System too Lean - Intermittent
Readiness: 0000 0000
'07 Transporter 1.9 TDI
'01 Beetle 2.0
If no air leaks the No1 02 sensor and airmass meters are common on these models...replaced so many....VDUB..
VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150BRISBANE / GOLD COAST
Thanks, guys..much appreciated..
