Results 1 to 4 of 4
Thread: Golf 4 Engine Fault Code Explanation - System Too Lean
    Jun 2009
    Eastwood, NSW
    G'day,
    Hooked up VCDS to my daughter's 2003 model 2.0 litre Golf 4 to see why it was consuming around 20 litres/ 100km. Got the following engine codes. I guess the engine ECU is over-compensating for the lean fuel mixture, hence the high fuel consumption. If I disconnect the battery for more than 15 mins, the fuel consumption improves to around 8.5 litres/100km (but then gradually deteriorates until the next battery reset).
    What do you think is the cause? Is there a code preset that can be done to fix the fuel mixture fault? Thanks..
    Address 01: Engine Labels: 06A-906-018-AQY.lbl
    Part No: 06A 906 018 GP
    Component: 2.0l R4/2V MOTR AT V01
    Coding: 00033
    Shop #: WSC 01271
    VCID: 76E3F91F52E30AAEB1B-4AE8
    2 Faults Found:
    16555 - Fuel Trim; Bank 1
    P0171 - 35-10 - System Too Lean - Intermittent
    17536 - Fuel Trim; Bank 1 (Mult)
    P1128 - 35-10 - System too Lean - Intermittent
    Readiness: 0000 0000
    Dec 2008
    Sydney/Canberra
    Look for splits in the intake pipe, breather hoses and vacuum hoses.
    The O2 sensor(s) are picking up a lean mixture after the air mass sensor.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Mar 2013
    Brisbane QLD
    If no air leaks the No1 02 sensor and airmass meters are common on these models...replaced so many....VDUB..
    VOLKSWAGEN TECHNICIAN - 16 YEARS OF PAIN..
    VCDS CODING- FAULT DIAGNOSIS - PRE PURCHASE INSPECTIONS- REPAIRS
    9W2 BT KITS -$300 - 9W7 BT KITS - $450 - CANBUS UPGRADE $150
    BRISBANE / GOLD COAST
    Jun 2009
    Eastwood, NSW
    Thanks, guys..much appreciated..
