Hi guys
I am not too good with reading my VCDS error messages and was looking for some help.
Basically I installed a Fiscon Basic Plus for bluetooth function but it seems intermittent and if I try to play A2DP from my iphone the bluetooth cuts in and out so the music stops/starts. The fit was tight so am wondering if the cable is twisted or somehow not connected well enough and is causing this issue
Any help is appreciated. Here is the message
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 7N0 907 530 HW: 1K0 907 951
Component: J533 Gateway H27 0602
Revision: H27 Serial number: 250510F2001812
Coding: EDA07F0640060200002303
Shop #: WSC 00010 959 95488
VCID: EDD54D878D01
2 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00110100
Fault Priority: 2
Fault Frequency: 3
Reset counter: 148
Mileage: 16113 km
Time Indication: 0
Date: 2020.14.30
Time: 13:41:33
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 148
Mileage: 16113 km
Time Indication: 0
Date: 2020.14.30
Time: 13:41:33
Address 77: Telephone Labels: None
Part No: KTC 364 96P
Component: SWP:3.11.8 H24
Shop #: WSC 21977 142 74100
VCID: 3E773ACB10E7
No Faults Found
or DTCs not supported by controller
or a communication error occurred
