metulmykul: hmm.......... the DTC in your autoscan is B2010 (see below)
Code:
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7N0 959 107 A HW: 7N0 959 107 A
Component: HDSG-Modul H11 0802
Revision: 41011001 Serial number: 250000031
Coding: 082301C002
Shop #: WSC 33361 790 00999
ASAM Dataset: EV_HDSGSk462 301133
ROD: EV_HDSGSk462_SK46.rod
VCID: B522611A14DEEBEEE9-80E0
1 Fault Found:
0004 - No Basic Setting
B2010 00 [137] - -
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 1
Fault Frequency: 1
Reset counter: 132
Mileage: 126920 km
Date: 2017.10.23
Time: 12:04:35
12.58 V
There is a specific instruction for the Skoda Supert (3T) for this DTC on the Ross-Tech wiki site - which I have copied for you below. Worth a try in my view!!
Basic Setting (from Ross-Tech wiki HERE)
Rear Lid relearn
Prerequisites:
- Rear Lid closed
- Transport mode NOT active
- No rear lid obstructions or damage to the vehicle
- Park assist functions correctly, no errors (If equipped)
- DTC B2010- No Basic Setting stored
- Battery voltage at least 12.0V
- Vehicle is on a flat level surface
[Select]
[6D-Trunk Elect.]
[Basic Settings - 04]
Select Adapt flap opening angle from the drop-down menu.
[Go!]
The rear lid Basic Settings will now begin and the rear lid will open.
Finished Correctly (or similar) should be displayed.
- When the rear lid has stopped, close the rear lid using the E406 switch.
[Stop]
[Done, Go Back]
- Check for fault codes, clear if needed.
[Close Controller, Go Back - 06]
- Check for proper operation
- Re-check for faults
