Hey mate, open your tail gate, once it's open hold down the button to close it and keep it held down untill you hear afew beeps... This will basic set your tailgate.
Greetings all.
MY11 Superb Kombi. Tailgate locks, unlocks but fails to open and close.
Any help appreciated, full scan available if required.
Code:Friday,20,October,2017,09:50:07:40733 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com Mileage: Repair Order: 201017 Address 6D: Trunk Elect. Control Module Part Number: 7N0 959 107 A Component and/or Version: HDSG-Modul H11 0802 Software Coding: 082301C002 Work Shop Code: WSC 33361 VCID: B522611A14DEEBEEE9-80E0 Advanced Identification/FAZIT Serial number: 250000031 Identification: TF7-MNL Revision: 41011001 Date: 07.09.10 Manufacturer number: 0001 Test stand number: 0031 Flash Status Programming Attempts(application): 0/0/0 Programming Attempts(data): 0 Successful Attempts(data): 0 Programming Status: 00000000 Flash Date: 00.00.00 Flash Tool Code: 00000 000 00000 Flash Tool Code(data): 00000 000 00000 Software UDS: 01.02.14 Diag: 01.03.00 CAN: 01.26.01 ISO15765: 01.02.15 UDS Std Diag: 01.01.00 Theft prot.: 00.00.00 OSEK-OS: 03.24.00 OSEK-Com: 04.07.02 Unknown: 01.00.08 Misc. Hardware number: 7N0 959 107 A Workshop System Name: ---- Equipment/PR Code: 0000000000000000 Dataset Number: 7N0959107A Dataset Version: D009 ASAM Dataset: EV_HDSGSk462 ASAM Dataset Revision: 301133 Car Info Chassis Number: ----------------- VCDS Info: VCID: B522611A14DEEBEEE9-80E0 Labels: 7N0-959-107.clb ROD: EV_HDSGSk462_SK46.rod Friday,20,October,2017,09:51:25:40733 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com Mileage: Repair Order: 201017 Address 6D: Trunk Elect. Labels: 7N0-959-107.clb Control Module Part Number: 7N0 959 107 A HW: 7N0 959 107 A Component and/or Version: HDSG-Modul H11 0802 Software Coding: 082301C002 Work Shop Code: WSC 33361 790 00999 ASAM Dataset: EV_HDSGSk462 301133 (SK46) ROD: EV_HDSGSk462_SK46.rod VCID: B522611A14DEEBEEE9-80E0 1 Fault Found: 0004 - No Basic Setting B2010 00 [137] - - MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 129 Mileage: 126440 km Date: 2080.14.29 Time: 10:46:56 12.64 V
Hey man.
Yep, tried that. Get the reset beeps but still no cigar...
Can you please post a full auto scan for me![]()
No worries.
Looks like i have to do it in 2 pieces
Code:Friday,20,October,2017,09:38:37:40733VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: TMBKF93T9B9023003 License Plate: Chassis Type: 3T-SK46 (7N0) Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 47 52 55 56 62 69 6D 72 77 VIN: TMBKF93T9B9023003 Mileage: 126440km-78566miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6D-Trunk Elect. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb Part No SW: 03L 906 018 CJ HW: 03L 906 018 BR Component: R4 2,0L EDC H22 7828 Revision: 42H22--- Serial number: Coding: 001D0012042500080000 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_ECM20TDI01103L906018CJ 003006 ROD: EV_ECM20TDI01103L906018CJ.rod VCID: F4A49C1E5F24B2E61E-80A0 No fault code found. Readiness: 0 0 0 0 0 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.clb Part No SW: 02E 300 052 H HW: 02E 927 770 AL Component: GSG DSG AG6 511 2208 Revision: 05151112 Serial number: 00001008231818 Coding: 0000020 Shop #: WSC 33361 790 00055 VCID: 997A8DAA50062F8EED-80CC No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE Component: ESP MK60EC1 H31 0108 Revision: 00H31001 Coding: 863D6016092400FD610B06E4901C0082350000 Shop #: WSC 33361 790 00055 VCID: F6A0A6164158A0F620-80A2 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS Component: Climatronic H15 0401 Revision: 00005001 Coding: 0000000002 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_SK35.rod VCID: 8346CFC20A8A855E17-80D6 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb Part No SW: 1K0 937 087 P HW: 1K0 937 087 P Component: BCM PQ35 H+ 104 0615 Revision: 00104 AE Coding: 42190AB8E84BF1C040080080110089EC447800AE737D85605C0140000040 Shop #: WSC 12345 123 61029 VCID: BE307E3629E828B638-80EA Subsystem 1 - Part No: 3T2 955 119 A Labels: 1KX-955-119.CLB Component: Wischer 20081 26 0602 Coding: 00D7B7 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 090910 05 54 0403 Coding: 0730ED Subsystem 3 - Part No: 7N0 951 171 Component: DWA-Sensor 00 002 0205 Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb Part No SW: 3T0 919 475 A HW: 3T0 919 475 Component: PARKHILFE PLA H07 0003 Revision: -------- Serial number: 78331020003064 Coding: 111108 Shop #: WSC 43125 959 96122 VCID: BB3677223AFA3D9E1F-80EE No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 3T0 959 655 B HW: 3T0 959 655 B Component: J234__LDE VW10 HI 1916 Revision: 19014000 Serial number: 003GRPJ695E Coding: 0017477 Shop #: WSC 33361 790 00999 VCID: C0CC00CE931C5E464A-8094 Subsystem 1 - Serial number: 6332MTS670412360 Subsystem 2 - Serial number: 6342MTS627852380 Subsystem 3 - Serial number: 6351HTS6VBK2E9KR Subsystem 4 - Serial number: 6361HTS6TAK2E9KR Subsystem 5 - Serial number: 63727TS65RK3E9KJ Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B Component: LENKS.MODUL 009 0136 Revision: FF010038 Serial number: 20100823300801 Coding: 189A140000 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_SMLSNGVOLWS A01004 ROD: EV_SMLSNGVOLWS.rod VCID: FEB0BE366168E8B678-80AA Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3T0 959 537 A HW: 3T0 959 537 A Labels: 3C8-959-537.CLB Component: E221__MFL-URO H07 0012 Coding: 830000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb Part No SW: 3T2 920 841 H HW: 3T2 920 841 H Component: KOMBI H04 0406 Serial number: 00000000000000 Coding: 711F01 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089 ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod VCID: B93A6D2A38C60F8E0D-80EC No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb Part No SW: 7N0 907 530 HW: 1K0 907 951 Component: J533 Gateway H27 5603 Revision: H27 Serial number: 040910F1001702 Coding: EDA1FF4652060200002303 Shop #: WSC 22690 959 14172 VCID: ED92897AF40E632ED1-80B8 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0406 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: EA9882660DE07416B4-80BE No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl Part No SW: 3C8 959 760 HW: 3C8 959 760 Component: J810 0801 Revision: 00002000 Serial number: 00000000000000 Coding: 0000003 Shop #: WSC 12345 111 45725 VCID: F2A89A06ED30BCD60C-80A6 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb Part No SW: 3T0 035 680 G HW: 3T0 035 680 A Component: RNS-MID H42 5238 Revision: AB001001 Serial number: SKZ6Z7K7252099 Coding: 04060002000000A10000 Shop #: WSC 12345 123 61029 VCID: B4245C1E17A4F2E6DE-80E0 Subsystem 1 - Part No: 3T0 051 859 AE Component: AUNZ V8 8207 No fault code found. -------------------------------------------------------------------------------
Part 2...
Code:Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb Part No SW: 8X0 959 793 C HW: 8X0 959 793 C Component: TSG FA H09 0409 Revision: -------- Serial number: -------------- Coding: 011D0220DE01001000 Shop #: WSC 33361 790 00999 VCID: CDD229FA944E832EB1-8098 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 J Component: EPS_ZFLS Kl. 196 3001 Revision: 00H17000 Shop #: WSC 33361 790 00055 VCID: B12A550A28B6C7CEB5-80E4 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (R12) Labels: 5K0-035-456.clb Part No SW: 3T0 035 456 HW: 3T0 035 456 Component: KonzernAmp10K H06 0342 Revision: -------- Serial number: BP218209147708 ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003 ROD: EV_AudioVerst10KanalBNO1.rod VCID: EE908E7631089836E8-80BA No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb Part No SW: 8X0 959 792 C HW: 8X0 959 792 C Component: TSG BF H09 0409 Revision: -------- Serial number: -------------- Coding: 011D0220DE01001000 Shop #: WSC 33361 790 00055 VCID: CCD424FE6F548A26A6-8098 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0148 Revision: 00H04000 Serial number: Coding: 1377095 Shop #: WSC 33361 790 00999 VCID: B4245C1ED7A4F2E6DE-80E0 Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l 0004 Coding: 00000021 Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0004 Coding: 00000021 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels:. 1T0-035-680.clb Part No SW: 3T0 035 680 G HW: 3T0 035 680 A Component: RNS-MID H42 5238 Revision: AB001001 Serial number: SKZ6Z7K7252099 Coding: 04060002000000A10000 Shop #: WSC 12345 123 61029 VCID: B4245C1E17A4F2E6DE-80E0 Subsystem 1 - Part No: 3T0 051 859 AE Component: AUNZ V8 8207 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 8X0 959 795 B HW: 8X0 959 795 B Component: TSG HL H06 0409 Revision: -------- Serial number: -------------- Coding: 010C00200001001000 Shop #: WSC 33361 790 00999 VCID: CED02EF69948B836C8-809A No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb Part No SW: 1K0 907 383 F HW: 1K0 907 383 F Component: Anhaenger H07 0100 Revision: 3A001001 Serial number: 00000132524615 Coding: 0100000100000000 Shop #: WSC 00000 000 00000 VCID: B02C500EE3BCCEC6BA-80E4 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb Part No SW: 7N0 959 107 A HW: 7N0 959 107 A Component: HDSG-Modul H11 0802 Revision: 41011001 Serial number: 250000031 Coding: 082301C002 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_HDSGSk462 301133 ROD: EV_HDSGSk462_SK46.rod VCID: B522611A14DEEBEEE9-80E0 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 8X0 959 795 B HW: 8X0 959 795 B Component: TSG HR H06 0409 Revision: -------- Serial number: -------------- Coding: 010C00200001001000 Shop #: WSC 33361 790 00055 VCID: CED02EF69948B836C8-809A No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 7P6-035-730.clb Part No SW: 7P6 035 730 L HW: 7P6 035 730 L Component: TELEFON H15 3200 Revision: 1B001001 Serial number: 00AAAA63112800 Coding: 0A00000000000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_UHVNA 002720 ROD: EV_UHVNA_002.rod VCID: BB36772232FA3D9E1F-80EE 4 Faults Found: 9458195 - Control Module for Cellular Telephone B1052 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 127 Mileage: 126333 km Date: 2017.10.16 Time: 13:01:14 13636352 - Control module not coded U1013 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 127 Mileage: 126333 km Date: 2017.10.16 Time: 13:01:15 9457937 - Telephone baseplate B1051 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 127 Mileage: 126333 km Date: 2017.10.16 Time: 13:01:14 9458449 - Cellular Antenna B1053 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 127 Mileage: 126333 km Date: 2017.10.16 Time: 13:01:14 End----------(Elapsed Time: 01:40, VBatt start/end: 12.7V/12.6V)-----------
As you can see, 6D shows no fault codes in the Autoscan but shows an error as shown in first post.
Also shows this in adaptions. I assume it should read active but i can't get it to accept the change.
Code:Tuesday,17,October,2017,10:34:55:40733VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.0.1 (x64) HEX-NET CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: TMBKF93T9B9023003 License Plate: Mileage: 126360km-78516mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- UDS Adaptation Channel (1B): IDE01651-Status of adaptation Stored value not active
metulmykul: I'm not familiar with Superb Kombi cars, but just looking at your DTC information - isn't the descriptor "no basic setting" telling?
This type of error message normally means that the control module has lost its initializing calibration - I assume that there must be some type of calibration process for telling the module when the tailgate is at either end of its travel. Have you checked in the Basic Setting screen for the 6D module for a calibration process?
Hey Don.
Basic settings gives me...
IDE20176 Adapt flap opening angle and IDE20177 Adapt zero position for vehicle inclination
I've reset opening manually but not getting any joy.
Have just done autoscan via desktop and 6D is now showing fault code
Code:Monday,23,October,2017,12:05:26:40733VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 17.8.0.1 HEX-NET CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: TMBKF93T9B9023003 License Plate: Chassis Type: 3T-SK46 (7N0) Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 47 52 55 56 62 69 6D 72 77 VIN: TMBKF93T9B9023003 Mileage: 126920km-78864miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6D-Trunk Elect. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 01: Engine (J623-CFGB) Labels:. 03L-906-018-CFF.clb Part No SW: 03L 906 018 CJ HW: 03L 906 018 BR Component: R4 2,0L EDC H22 7828 Revision: 42H22--- Serial number: Coding: 001D0012042500080000 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_ECM20TDI01103L906018CJ 003006 ROD: EV_ECM20TDI01103L906018CJ.rod VCID: F4A49C1E5F24B2E61E-80A0 No fault code found. Readiness: 0 0 0 0 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 02E-927-770.clb Part No SW: 02E 300 052 H HW: 02E 927 770 AL Component: GSG DSG AG6 511 2208 Revision: 05151112 Serial number: 00001008231818 Coding: 0000020 Shop #: WSC 33361 790 00055 VCID: 997A8DAA50062F8EED-80CC No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 1K0-907-379-60EC1F.clb Part No SW: 1K0 907 379 BE HW: 1K0 907 379 BE Component: ESP MK60EC1 H31 0108 Revision: 00H31001 Coding: 863D6016092400FD610B06E4901C0082350000 Shop #: WSC 33361 790 00055 VCID: F6A0A6164158A0F620-80A2 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb Part No SW: 3T0 907 044 AS HW: 3T0 907 044 AS Component: Climatronic H15 0401 Revision: 00005001 Coding: 0000000002 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_Climatronic A01006 ROD: EV_ClimaAutoBasis_SK35.rod VCID: 8346CFC20A8A855E17-80D6 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb Part No SW: 1K0 937 087 P HW: 1K0 937 087 P Component: BCM PQ35 H+ 104 0615 Revision: 00104 AE Coding: 42190AB8E84BF1C040080080110089EC447800AE737D85605C0140000040 Shop #: WSC 12345 123 61029 VCID: BE307E3629E828B638-80EA Subsystem 1 - Part No: 3T2 955 119 A Labels: 1KX-955-119.CLB Component: Wischer 20081 26 0602 Coding: 00D7B7 Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB Component: RLS 090910 05 54 0403 Coding: 0730ED Subsystem 3 - Part No: 7N0 951 171 Component: DWA-Sensor 00 002 0205 Subsystem 4 - Part No: 1K0 951 605 C Component: LIN BACKUP HO H05 1501 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:. 1T0-919-475.clb Part No SW: 3T0 919 475 A HW: 3T0 919 475 Component: PARKHILFE PLA H07 0003 Revision: -------- Serial number: 78331020003064 Coding: 111108 Shop #: WSC 43125 959 96122 VCID: BB3677223AFA3D9E1F-80EE No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 5N0-959-655.lbl Part No SW: 3T0 959 655 B HW: 3T0 959 655 B Component: J234__LDE VW10 HI 1916 Revision: 19014000 Serial number: 003GRPJ695E Coding: 0017477 Shop #: WSC 33361 790 00999 VCID: C0CC00CE931C5E464A-8094 Subsystem 1 - Serial number: 6332MTS670412360 Subsystem 2 - Serial number: 6342MTS627852380 Subsystem 3 - Serial number: 6351HTS6VBK2E9KR Subsystem 4 - Serial number: 6361HTS6TAK2E9KR Subsystem 5 - Serial number: 63727TS65RK3E9KJ Subsystem 6 - Serial number: 00000000000000000 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5K0-953-569.clb Part No SW: 5K0 953 521 AT HW: 5K0 953 569 B Component: LENKS.MODUL 009 0136 Revision: FF010038 Serial number: 20100823300801 Coding: 189A140000 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_SMLSNGVOLWS A01004 ROD: EV_SMLSNGVOLWS.rod VCID: FEB0BE366168E8B678-80AA Multifunction steering wheel control module: Subsystem 1 - Part No SW: 3T0 959 537 A HW: 3T0 959 537 A Labels: 3C8-959-537.CLB Component: E221__MFL-URO H07 0012 Coding: 830000 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb Part No SW: 3T2 920 841 H HW: 3T2 920 841 H Component: KOMBI H04 0406 Serial number: 00000000000000 Coding: 711F01 Shop #: WSC 12345 123 61029 ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089 ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod VCID: B93A6D2A38C60F8E0D-80EC No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 7N0-907-530-V1.clb Part No SW: 7N0 907 530 HW: 1K0 907 951 Component: J533 Gateway H27 5603 Revision: H27 Serial number: 040910F1001702 Coding: EDA1FF4652060200002303 Shop #: WSC 22690 959 14172 VCID: ED92897AF40E632ED1-80B8 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb Part No SW: 5K0 953 234 HW: 5K0 953 234 Component: IMMO H04 0406 Serial number: 00000000000000 Coding: 000000 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008 ROD: EV_Immo_UDS_VDD_RM09_VW21.rod VCID: EA9882660DE07416B4-80BE No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl Part No SW: 3C8 959 760 HW: 3C8 959 760 Component: J810 0801 Revision: 00002000 Serial number: 00000000000000 Coding: 0000003 Shop #: WSC 12345 111 45725 VCID: F2A89A06ED30BCD60C-80A6 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb Part No SW: 3T0 035 680 G HW: 3T0 035 680 A Component: RNS-MID H42 5238 Revision: AB001001 Serial number: SKZ6Z7K7252099 Coding: 04060002000000A10000 Shop #: WSC 12345 123 61029 VCID: B4245C1E17A4F2E6DE-80E0 Subsystem 1 - Part No: 3T0 051 859 AE Component: AUNZ V8 8207 No fault code found.
Code:Monday,23,October,2017,12:05:26:40733VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 17.8.0.1 HEX-NET CB: 0.4401.4 Data version: 20170721 DS276.2 www.Ross-Tech.com VIN: TMBKF93T9B9023003 License Plate: Chassis Type: 3T-SK46 (7N0) Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 47 52 55 56 62 69 6D 72 77 VIN: TMBKF93T9B9023003 Mileage: 126920km-78864miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: OK 0000 6D-Trunk Elect. -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 77-Telephone -- Status: Malfunction 0010 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:. 8X0-959-793.clb Part No SW: 8X0 959 793 C HW: 8X0 959 793 C Component: TSG FA H09 0409 Revision: -------- Serial number: -------------- Coding: 011D0220DE01001000 Shop #: WSC 33361 790 00999 VCID: CDD229FA944E832EB1-8098 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb Part No: 1K0 909 144 J Component: EPS_ZFLS Kl. 196 3001 Revision: 00H17000 Shop #: WSC 33361 790 00055 VCID: B12A550A28B6C7CEB5-80E4 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System (R12) Labels: 5K0-035-456.clb Part No SW: 3T0 035 456 HW: 3T0 035 456 Component: KonzernAmp10K H06 0342 Revision: -------- Serial number: BP218209147708 ASAM Dataset: EV_AudioVerst10KanalBNO1 A01003 ROD: EV_AudioVerst10KanalBNO1.rod VCID: EE908E7631089836E8-80BA No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:. 8X0-959-792.clb Part No SW: 8X0 959 792 C HW: 8X0 959 792 C Component: TSG BF H09 0409 Revision: -------- Serial number: -------------- Coding: 011D0220DE01001000 Shop #: WSC 33361 790 00055 VCID: CCD424FE6F548A26A6-8098 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl Part No SW: 5M0 907 357 C HW: 5M0 907 357 C Component: AFS-Steuergeraet 0148 Revision: 00H04000 Serial number: Coding: 1377095 Shop #: WSC 33361 790 00999 VCID: B4245C1ED7A4F2E6DE-80E0 Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul l 0004 Coding: 00000021 Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB Component: AFS-Lst.-Modul r 0004 Coding: 00000021 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio (J0506) Labels:. 1T0-035-680.clb Part No SW: 3T0 035 680 G HW: 3T0 035 680 A Component: RNS-MID H42 5238 Revision: AB001001 Serial number: SKZ6Z7K7252099 Coding: 04060002000000A10000 Shop #: WSC 12345 123 61029 VCID: B4245C1E17A4F2E6DE-80E0 Subsystem 1 - Part No: 3T0 051 859 AE Component: AUNZ V8 8207 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left (J388) Labels: None Part No SW: 8X0 959 795 B HW: 8X0 959 795 B Component: TSG HL H06 0409 Revision: -------- Serial number: -------------- Coding: 010C00200001001000 Shop #: WSC 33361 790 00999 VCID: CED02EF69948B836C8-809A No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb Part No SW: 1K0 907 383 F HW: 1K0 907 383 F Component: Anhaenger H07 0100 Revision: 3A001001 Serial number: 00000132524615 Coding: 0100000100000000 Shop #: WSC 00000 000 00000 VCID: B02C500EE3BCCEC6BA-80E4 No fault code found. ------------------------------------------------------------------------------- Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb Part No SW: 7N0 959 107 A HW: 7N0 959 107 A Component: HDSG-Modul H11 0802 Revision: 41011001 Serial number: 250000031 Coding: 082301C002 Shop #: WSC 33361 790 00999 ASAM Dataset: EV_HDSGSk462 301133 ROD: EV_HDSGSk462_SK46.rod VCID: B522611A14DEEBEEE9-80E0 1 Fault Found: 0004 - No Basic Setting B2010 00 [137] - - MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 1 Fault Frequency: 1 Reset counter: 132 Mileage: 126920 km Date: 2017.10.23 Time: 12:04:35 12.58 V ------------------------------------------------------------------------------- Address 72: Door, Rear Right (J389) Labels: None Part No SW: 8X0 959 795 B HW: 8X0 959 795 B Component: TSG HR H06 0409 Revision: -------- Serial number: -------------- Coding: 010C00200001001000 Shop #: WSC 33361 790 00055 VCID: CED02EF69948B836C8-809A No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone (J412) Labels:| 7P6-035-730.clb Part No SW: 7P6 035 730 L HW: 7P6 035 730 L Component: TELEFON H15 3200 Revision: 1B001001 Serial number: 00AAAA63112800 Coding: 0A00000000000001 Shop #: WSC 00000 000 00000 ASAM Dataset: EV_UHVNA 002720 ROD: EV_UHVNA_002.rod VCID: BB36772232FA3D9E1F-80EE 4 Faults Found: 9458195 - Control Module for Cellular Telephone B1052 13 [009] - Open Circuit Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 132 Mileage: 126920 km Date: 2017.10.23 Time: 12:04:35 13636352 - Control module not coded U1013 00 [009] - - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 132 Mileage: 126920 km Date: 2017.10.23 Time: 12:04:37 9457937 - Telephone baseplate B1051 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 132 Mileage: 126920 km Date: 2017.10.23 Time: 12:04:35 9458449 - Cellular Antenna B1053 11 [009] - Short to Ground Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 4 Fault Frequency: 1 Reset counter: 132 Mileage: 126920 km Date: 2017.10.23 Time: 12:04:35 End----------(Elapsed Time: 01:35, VBatt start/end: 12.5V/12.5V)-----------
