6-Speed Direct Shift Gearbox (DSG/02E)Basic Setting
Prerequisites:
- Fluid Temperature 30...100 °C (86...210 °F), see Measuring Blocks, Group 019. (Fluid Level needs to be correct!)
- Selector Lever in P
- Ignition ON
- Engine ON (Idling) for one minute or more
- Brake Pedal operated (hold for the whole procedure)
- Throttle Pedal not operated
NOTE: Be sure to perform the following steps in the sequence shown, followed by the defined test drive.
[Select]
[02 - Transmission]
[Basic Settings - 04]
Transmission Tolerances (Engaged Calibration)
Group 061
[Go!]
- When you go to Basic Settings 061 and click GO the screen may look like this: Basic Settings 061
- Wait until the numbers quit moving and the trans will quit making noises. Basic Settings switches to On when finished: Basic Settings 061
Wait until Basic Settings has switched to ON and all numbers have stopped moving. This may take one minute.
Transmission Tolerances (Synch. Point. Measurement)
Group 060
[Go!]
- When you go to Basic Settings 060 and click GO the screen may look like this: Basic Settings 060
- Wait until the numbers quit moving and the trans will quit making noises. Basic Settings switches to On when finished: Basic Settings 060
Clutch Adaptation
Control Module Software Version < 0800:
Group 062
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Special notes.
- When found in the early software level (0627/0628 )(8N) Audi TT:
- Basic Settings group 062 may take several minutes to complete. The final values may report: [18 | 18 | .285 | .24] and Basic Settings will report ON when finished.
- If Basic Settings group 062 reports ERROR:| Group 062| Not | Available try test driving the vehicle and repeating at normal operating temp.
Internal Ref: ST?ID=66725 and E?ID=309867
Control Module Software Version >= 0800 :
Group 067
[Go!]
[ON/OFF/Next]
Reset Values (Clutch Safety Function)
Group 068
[Go!]
[ON/OFF/Next]
Reset Values (Pressure Adaptation)
Group 065
[Go!]
[ON/OFF/Next]
Reset Values (Steering Wheel Paddle Installation)
Group 063
[Go!]
[ON/OFF/Next]
Reset Values (ESP & Tip Cruise Control Installation)
Group 069
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Switch off Ignition, wait 10 Seconds and switch it back on.
[Fault Codes - 02]
Check and clear fault codes after successful test.
[Close Controller, Go Back - 06]
Perform the Defined Test Drive.
Special Procedures
Defined Test Drive
Suggested test drive after replacing the mechatronic or successful basic setting.
Prerequisites:
- Do Not use Cruise Control.
Drive in Tiptronic Mode from stand still up to 6th Gear.
While doing that make sure to drive in Gears 3 or 5 for approx. 5 minutes and also in 4 or 6 for approx. 5 minutes.
The engine speed window for all gears is 1200 - 3500 RPM (for clutch calibration).
Perform one sharp braking followed by a full throttle acceleration (oil return check) while in Drive, Not Tiptronic Mode.
Evaluate creep and starting-off points.
Check for leaks.
NOTE: If the test drive cannot be performed in the recommended way or the necessary time, any remaining adaptations will be performed automatically during normal driving.
Special Notes
- Some modules do not require the use if the [ON/OFF/Next] button. If an Error is displayed after clicking the button, or the Basic Settings status does not switch to On, let the selected group and procedure finish on its own.
- It is normal for the transmission to make noise while the tolerances are adapting. Do not exit or abort the Basic Settings sequence prematurely if you hear clacking noises.
- Customers with TDI's have reported that an RPM range of 2000-2500 rpm is sufficient.
