Results 1 to 3 of 3
Thread: DSG Re-Calibration OBDeleven?
    Hi Guys,
    For 2008/9 Passat R36, what tool do i need to run the DSG Re-cal, the one that takes 5-6 mins of clicking and clacking solenoids firing and clunking etc...
    can this be done with OBDeleven much in the same way the throttle body re-cal can be done?
    Cheers,
    Mat
    Quote Originally Posted by MatC View Post
    Hi Guys,
    Cheers,
    Mat
    Mat - haven't done it myself, but should be exactly the same as this - taken from Ross-Tech website:
    Quote Originally Posted by Ross-Tech
    6-Speed Direct Shift Gearbox (DSG/02E)
    Basic Setting
    Prerequisites:
    • Fluid Temperature 30...100 °C (86...210 °F), see Measuring Blocks, Group 019. (Fluid Level needs to be correct!)
    • Selector Lever in P
    • Ignition ON
    • Engine ON (Idling) for one minute or more
    • Brake Pedal operated (hold for the whole procedure)
    • Throttle Pedal not operated
    NOTE: Be sure to perform the following steps in the sequence shown, followed by the defined test drive.
    [Select]
    [02 - Transmission]
    [Basic Settings - 04]
    Transmission Tolerances (Engaged Calibration)
    Group 061
    [Go!]
    • When you go to Basic Settings 061 and click GO the screen may look like this: Basic Settings 061
    • Wait until the numbers quit moving and the trans will quit making noises. Basic Settings switches to On when finished: Basic Settings 061
    Wait until Basic Settings has switched to ON and all numbers have stopped moving. This may take one minute.
    Transmission Tolerances (Synch. Point. Measurement)
    Group 060
    [Go!]
    • When you go to Basic Settings 060 and click GO the screen may look like this: Basic Settings 060
    • Wait until the numbers quit moving and the trans will quit making noises. Basic Settings switches to On when finished: Basic Settings 060
    Clutch Adaptation
    Control Module Software Version < 0800:
    Group 062
    [Go!]
    Activate the Basic Setting.
    [ON/OFF/Next]
    Special notes.
    • When found in the early software level (0627/0628 )(8N) Audi TT:
      • Basic Settings group 062 may take several minutes to complete. The final values may report: [18 | 18 | .285 | .24] and Basic Settings will report ON when finished.
      • If Basic Settings group 062 reports ERROR:| Group 062| Not | Available try test driving the vehicle and repeating at normal operating temp.
    Internal Ref: ST?ID=66725 and E?ID=309867
    Control Module Software Version >= 0800 :
    Group 067
    [Go!]
    [ON/OFF/Next]
    Reset Values (Clutch Safety Function)
    Group 068
    [Go!]
    [ON/OFF/Next]
    Reset Values (Pressure Adaptation)
    Group 065
    [Go!]
    [ON/OFF/Next]
    Reset Values (Steering Wheel Paddle Installation)
    Group 063
    [Go!]
    [ON/OFF/Next]
    Reset Values (ESP & Tip Cruise Control Installation)
    Group 069
    [Go!]
    [ON/OFF/Next]
    [Done, Go Back]
    Switch off Ignition, wait 10 Seconds and switch it back on.
    [Fault Codes - 02]
    Check and clear fault codes after successful test.
    [Close Controller, Go Back - 06]
    Perform the Defined Test Drive.
    Special Procedures
    Defined Test Drive
    Suggested test drive after replacing the mechatronic or successful basic setting.
    Prerequisites:
    • Do Not use Cruise Control.
    Drive in Tiptronic Mode from stand still up to 6th Gear.
    While doing that make sure to drive in Gears 3 or 5 for approx. 5 minutes and also in 4 or 6 for approx. 5 minutes.
    The engine speed window for all gears is 1200 - 3500 RPM (for clutch calibration).
    Perform one sharp braking followed by a full throttle acceleration (oil return check) while in Drive, Not Tiptronic Mode.
    Evaluate creep and starting-off points.
    Check for leaks.
    NOTE: If the test drive cannot be performed in the recommended way or the necessary time, any remaining adaptations will be performed automatically during normal driving.
    Special Notes
    • Some modules do not require the use if the [ON/OFF/Next] button. If an Error is displayed after clicking the button, or the Basic Settings status does not switch to On, let the selected group and procedure finish on its own.
    • It is normal for the transmission to make noise while the tolerances are adapting. Do not exit or abort the Basic Settings sequence prematurely if you hear clacking noises.
    • Customers with TDI's have reported that an RPM range of 2000-2500 rpm is sufficient.
    thank you for that, can it be done/activated from OBDeleven, or do i need VCDS cable + subscription etc..
